W212 Sudden idle Drops and surges after starting engine
the engine starts normally and idle raise as it should on cold but suddenly after 1 or 2 seconds there is some fast and random idle drops then the engine recovers. it runs nicely when driving without any problem. the problem only appears when you first start the car. The check engine light keeps coming on after this behavior. (i m waiting for the weekend so i can hook it up to my friend scanner and see which code it is throwing). please check this YouTube video that describes my problem:
could it be the replaced CKPS is bad also? Your help is appreciated. thanking you in advance
It's possible the used sensor is bad, but I suggest verifying the circuit itself is ok. Start with the connector, ensuring its clean and the wiring is intact. Continuity can be checked from the connector pins back to the pcm plug pins.
If it all worked until before you worked on the car, then it could be the sensor or connector is still damaged from oil or an inadvertently pulled wire. If you get a new sensor, I suggest an oem sensor, but then I'm one of those guys that never seems to have good luck with after market sensors. But for sure take a close look at the connector.
Your mechanic should have access to vehicle wiring and connector diagrams - are they doing additional diagnosis or just installing parts? Typically almost any scan tool can capture freeze frame data that is stored when a code is thrown, this data can help focus on what was happening when the pcm determined something was out of range. Scantool that I hope a shop would have can also read real time data that can show things like crank and cam rotation, cylinder firing, etc. that can lead to an effective diagnosis.
I mention all this because too many times shops start installing parts hoping that's the fix. Maybe they will get lucky with the cam sensors but if not, then I think you need someone that can access and interpret data.
My next step will be the mb dealer i guess.
I understand the dealer is a high cost but sometimes paying for the right diagnosis up front is worth it.
Flexplates (flywheel) can get cracked or can possibly get a chipped or broken tooth on the ring gear. Usually a broken tooth shows up in hearing the starter slip as the starter gear hits the space where the flexplate tooth used to be. There should be an inspection cover at the bellhousing that allows visual inspection of the ring gear as the engine is turned by hand or a camera probe can be used in the hole where the CPS goes.
But all this may be getting ahead of ourselves, get it evaluated first.
