w212 2010 550 4matic Airmatic Malfunction Issue
I dont feel there is a leak in the suspension due to the lack of sagging. I did notice when I purchased the car that the compressor would go on when I started the car and was not constantly running. Any thoughts to help this novice diagnose the issue?
https://mbworld.org/forums/e-class-w...ner-again.html
The short answer is different scanners will provider you with different functionality and different info. Two of the more recommended scanners seem to be Konnwei KW850 and iCarsoft.
an OBD2 reader is not going to tell you jack-shizz about airmatic fault codes... Get at least an Autel or Launch basic model.
