UPDATE: not my secondary air pump..I wish it was though.. what now?
"customer states there is a whining noise that gets louder the higher the RPMs are. noticeable over 25 mph, thought it was secondary air pump and changed it himself but noise is still present.
109901 Bad trans road tested and heard the noise it is a bearing noise so put on rack and had a tech put into drive so we could find where the noise is coming from. it is not wheel bearing noise. the noise is coming from the rear pinion of the transmission. it is very loud and has a vibration also the parts are not serviceable. would have to replace complete transmission"
they quoted me $8,686.50!! i think that's about how much the car is worth now ahahah.
i love the car but i think i will just have to sell it now before the tranny completely craps out and let the next guy deal with it.
2010 4matic with 110K miles on it. so bummed.
A used transmission maybe?
My friend just had an issues with his tranny in 2011 bmw 528 , bought a used one .... long story short 8t all came up to 3k.
....just checked there are some on ebay (also i would check other places , and specifically car-part.com) from 800-1400. Plus labor another grand roughly depending on a shop. Some coding may be required also so another couple hundred bucks. So u probably be looking around 3k as well.
I know it is still a lot , but better than 8k dealer quoted you.
i'm assuming i can swap out up to 2016 model?
722.960 type, part number: 2122701409
This is why its very important to find a local Mercedes wizard to do actual diagnostic on the car instead of just going out to get "needs new tranny" service write up. I used to think that the dealer was the know-all end-all mercedes Bible, but it seems like there is a technician lottery just as much at the dealer as any other mechanic shop.
I hope they didn't charge you more than $50 for that vague-azz diagnostic.
Thank you for the heads up! There wasn't a charge for them to look at my car.
They also say it is non-serviceable part. This is total crap! Everything from the engine to the wheels is serviceable in the power transmission system but MB itself does not do that. They just change "modules" like the whole transmission for an issue like this.
Yes, it take work to get to the failed bearing that probably cost less than $100. Bearings are very cheap and as the bearing failed you could probably even replace it with a stronger one that fits in the same space.
But, in the other hand, if MB puts on a whole new transmission for less than $9000 it really is not that bad. My car book value is less than $10000. It has 161000 miles on it and no way in hell I would sell it. It has all options other than night view and I absolutely love the car. If my transmission went out I would not hesitate one second getting it replaced as the other option is WAY more expensive and for E-class I would not get one anyway. They are ugly!
Why spend way more money for another car that is no way better than what I have.
The car is old and no book value but I don't drive the book. I drive a very nice car with lots of smiles still coming.
This happened to me, same car roughly same mileage, it was a bearing in the transfer case. My Mercedes indie rebuilt it for $2300 plus transmission flush 500 plus a transmission mount all total with tax $3200
My 99 Audi made 220K and I tracked it without this BS. Splitting seats, fading wood, motor mounts that go, transmission that doesn't shift right. Its never really all that smooth (brand new Michelins) the car is really starting to suck.
Just for you I ran out to my car in the rain and pulled the receipt, There is a $35.20 charge for a transfer case bearing and another $130.90 charge for a Timken bearing plus $20.35 for a radial shaft ring plus $100 of stuff including parts for the license plate lights.
I've seen the parts on line for not too much money.
The point to the OP is you don't have to replace the transmission.
I guess what I am saying is that I think that you can get it repaired even cheaper than I did. My son who is a pretty good wrench and even had his own shop for a short period of time thought I was overcharged for the repair.
