Replace Front Wheel Bearings/Races
I'm looking to replace the front inner and outer wheel bearings and races on E550 Base. Rather than spend $300 per hub assembly from Mercedes that comes with bearings and seal, I decided to order just the bearings from a dealership via Amazon. Package cam promptly, but discovered the bearings are not the same size, therefore do not fit hub. Has anyone had good luck replacing bearings, and if so, where did you find the bearings? Apparently, dealers can only sell the hub assembly, and I've no luck finding bearings online through sites such as AutohausAZ. My local NAPA has them (at least so they say), but I'm leery of getting parts from NAPA, Autozone, etc. I also noted when I took the bearings and races out, outer race was made in Japan and inner was made in India. Vehicle has 95k miles, I'm the 2nd owner, so I'm wondering if the bearings have been replaced before.
