Who sells new front air struts for E550?
https://mbworld.org/forums/e-class-w...ml#post7707789
Frim what I now understand the companies who sell refurbished air struts for these w212 cars only do a send in refurbish service because the strut itself is a sealed shock that cannot be refurbished.they rebuild the airbag top but if the oil filled shock portion is bad it won’t improve. That’s why cores are in such short supply.
Looks like my best option like others have said is to buy new parts from MB.
EDIT: my symptoms were clunking when cold over bumps but would go away as the car warmed up.
To verify it was the strut I did the same side-by-side comparison securing the AirPod microphone to the side of the strut below the airbag next to the wheel And just as a baseline comparison I attached the AirPod microphone to a suspension arm on the noisy side of the car and listened to it.
Now that I have a very strong suspicion that the strut itself is bad I was able to order the part through one of my local Mercedes dealers and they even gave me a discount off and online source. Hope this helps others.
These w212 front air struts are dead when the oil filled strut shock goes bad so if you have one rebuilt the bag will hold air but the strut will be in the same condition the as you send to them. If yours goes bad like my drivers side did you have to get an OEM Mercedes part which now are being sold as remanufactired or try your luck with a salvage or used part.
https://www.oembenzparts.com/oem-par...t-212320323880
https://www.oembenzparts.com/oem-par...t-212320313880
If if this happens to your vehicle there’s no point in sending.your bad strut to a rebuilder. These struts are a sealed unit that can’t be rebuilt so all you’ll get for the $500+ is your bad strut back with a new air bellows.
I was really hesitant to begin this because other videos and DIY‘s on doing this on other models show having two separate bowl joints which I’m hesitant to do. I shot some video as I was doing the process of removing and reinstalling so if there’s any interest I will share what I learned in the process
My right front aromatic strut is not making any noise and has not leaked or given me any reason to replace it and at $1000 I’m just not willing to do it yet although The boot is trashed so I may remove it just to install a new boot. No one seems to have one in stock so looks like I’ll have to find one online
