Sponsored by: CARiD
Differential fluid for 2011 E350 4matic
Old Apr 28, 2024 | 11:15 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
These nightmare plugs are not standard nuts and bolts.
The diff plug unlike engine drain plug is sealed with its clever shape: IT IS CONICAL, no crush-washer, hollow head.
So FYI the front diff is not conical like usual ones. It is same/similar as transmission and has a crush washer.
Fumoto makes fine products. I used to have one 20 years ago on my oil pan. It's super convenient
However the diff plugs are low and very exposed to hazardous road projections.
Do they have a valve that is flush ?
With a magnetic plug 40kMi schedule is ultra conservative... no need frequent access, right?
The fumoto I got will not work as you mentioned not enough clearance. I did get one of the oil drain magnetic plugs however the washer and plug are slightly larger then the flat spot machined into the front diff. Gonna look for another washer to fit correctly or grind down the one that came with it.
Overall changing the front diff fluid is pretty darn easy once your are in the area. Mine looked really dark and definitely needed it. Hopefully I can get the magnetic plug to work correctly as I think it really needs it. Just about every diff I have changed fluid on has had one, not sure why they wouldnt do it on these.
Old Apr 29, 2024 | 02:12 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
NO Problem...
Originally Posted by MBNUT1
Did replacing the fluid quiet the rear end at all?
I am thinking mine might be starting to whine.
Nope, is the answer. Sorry now you are listening to the input bearing freeplay >>> NO WORRIES: put a MAG PLUG on it.
Save your money for gas, not that
