Differential fluid for 2011 E350 4matic
After searching the forum and I couldn't find the answer so I just post it again.
What kind of differential fluid we can use for our Benz?
Some thread said we should stick to 75W-85 from the Stealership. Other said, 75W-90 synthetic can be used..
Which one can we really use?
Thanks a lot.
I replaced the fluid on mine awhile back, pretty easy with drain/fill plugs in the unit. Mine was under ELW so I used the MB spec 235.7 gear oil (75W85). Ordered it online.
But my understanding is that many dealers use M1 or equivalent 75W90 gear oil without any problems.
Front diff is another story with a 4matic - very fiddly work....
I look up Amazon for Mercedes 75W85 quart and it will be 5 days shipping but I can buy Mobile1 75W-90 at local auto part store and get it done tomorrow.
The car is a little over 90K miles and I don't think the differential fluid has been changed recently.
The fill plug is not that hard to reach but the drain plug is way more difficult.
I had to use the 1/2" extension and 90degree elbow to get to it. The exhaust pipe is in the way.
Overall it wasn't that bad. It takes about 1.3 quarts to fill up and start to see the fluid dripping out.
Thanks a lot.[/QUOTE
Differential oil change is strange thing as my service manual does not mention it at all. I had transmission service done at 160000 miles and I asked the dealer that I would like that done too but cannot find recommendation for it in the service booklet. The technician said it is not really in the schedule but it would be good time to do it and it was done.
Receipt does not say what oil they used. it reads "001-989-17-03-10 hypoid transmis" I guess this is a MB part number for the oil.
It looked like SAE 75W-90 on the label of the bottle but i didn't see it clear.
I went with 75W-90 Mobil1 and didn't see anything different.
Thanks Arrie.
I use this transfer pump around $12 bucks at part store.
I changed my Diff at 93K and fluid coming out was same color as new stuff I put in.. Here
I used above pump, screws in to bottle and just pump away!
Good luck, Bob
The old rear fluid came out very dark so it was obviously past due, and the front fluid was red
No idea if it was ever changed (it was pretty clean looking) or if the fluid that came out was the right stuff or not.
RWD rear end
convenient soft pouch Diff oil container
This basic service is a lot of fun... the access ports are both hard to reach
Using the Valvoline oil in a pouch helps make the fill up ultra simple.
> *** FYI ***:
The stock plug is non magnetic so the oil is loaded with contaminents waiting for your attention.
M24x1.5 mag plug by the "DIMPLE Products Co"
Replace stock with a $50 magnetic type is cheaper than a new diff input bearing.
RWD rear end
> *** FYI ***:
Is this process for the front differential?
is this for the front differential?
RWD rear end
> *** FYI ***:
ADD : I am explaining REAR DIFF
The LOWEST one is always the drain plug.
The slightly higher one is the FILL plug.
Always loosen FILL plug first and if it can be loosen, you the proceed to loosen the DRAIN plug and drain the oil.
Often the FILL plug get seized and how would you fill up the DIFF if that FILL plug seized ?
FILL limit is when oil is at the lowest portion of FILL hole .....ready to puke out.
The diff plug unlike engine drain plug is sealed with its clever shape: IT IS CONICAL, no crush-washer, hollow head.
However the diff plugs are low and very exposed to hazardous road projections.
Do they have a valve that is flush ?
With a magnetic plug 40kMi schedule is ultra conservative... no need frequent access, right?
You are probably correct in how Ill end up doing it in the future, just thinking of ideas for the first time I tackle it.
