Sponsored by: CARiD
good battery...dead car!!
Old Jun 26, 2019 | 06:43 PM
Nikontom's Avatar
2014 e350 4 matic
My E350 2014 is dead. There is battery power based on my charger. 100%. Absolutely no noise when I try to start. Nothing happens wit hthe remote open key, trunk release. physical trunk relesase inside car does nothing.
I saw the side amber light flash so there is some power going somewhere.
I checked the fuses but did not pull all of them out.
other facts: recently used the battery to jump my other car. It did not work. After this, the car drove fine.
I am lost. Anyone have any ideas?
Old Jun 27, 2019 | 05:21 AM
optimusprime m1's Avatar
W124 260E
Looks like EIS but first check fuses 31 - 52 - 57.. The EIS will need replacing and programing at mercedes along with the set of new keys. Other part that gives the same problem is the SAM unit .In your case i think you should visit Mercedes and get it sorted out . Sorry and hope you find an easy fix -but
Old Jun 27, 2019 | 05:27 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
I would check cables first. Then I would pull the battery and take to auto parts store for testing just to be sure. Then report back.
Old Jun 28, 2019 | 10:29 AM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
Take a look at this before your dealer gets involved.
https://www.pressertech.com/blog/fau...ment-solution/
Some of the common reasons an EIS might falter:
  • Performing a jump while the key is inserted
Old Jun 28, 2019 | 12:15 PM
DFWdude's Avatar
2016 E350 Sport
Definitely check the battery again.
My C320 had a parasitic drain caused by the module under the passenger seat controlling the seat adjustment switches. I could insert the key in the EIS, but it would not turn. I had to jump start the car to get it to start. Then off to the Indy repair guy.
