Faraday Cages for Keyless Go Fob Security
Also after all your experiments with faraday cages, I started thinking, always a problem. I remembered when I had two EZ Passes in the car and was getting charged on both as I went through toll booths, they sent me two small matallized plastic bags to put the EZ Pass in when not in use, when I put my key in the bag my 13 does nothing even with the key inches from the drivers door handle!
Try to lock your car by touching inner handle and immediately open it by touching outside of handle.
Depends on the timing you will notice few seconds delay. That will give you idea about pinging intervals.
https://en.wikipedia.org/wiki/Smart_key#Keyless_Go
Keyless Go
Keyless Go (also: Keyless Entry / Go; Passive Entry / Go) is Mercedes' term for an automotive technology which allows a driver to lock and unlock a vehicle without using the corresponding SmartKey buttons. Once a driver enters a vehicle with an equipped Keyless Go SmartKey or Keyless Go wallet-size card, they have the ability to start and stop the engine, without inserting the SmartKey. A transponder built within the SmartKey allows the vehicle to identify a driver. An additional safety feature is integrated into the vehicle, making it impossible to lock a SmartKey with Keyless Go inside a vehicle.Hardware blocks on the Keyless Entry/Go ECU
The system works by having a series of LF (low frequency 125 kHz) transmitting antennas both inside and outside the vehicle. The external antennas are located in the door handles. When the vehicle is triggered, either by pulling the handle or touching the handle, an LF signal is transmitted from the antennas to the key. The key becomes activated if it is sufficiently close and it transmits its ID back to the vehicle via RF (Radio frequency >300 MHz) to a receiver located in the vehicle. If the key has the correct ID, the PASE module unlocks the vehicle.
The hardware blocks of a Keyless Entry / Go Electronic control unit ECU are based on its functionality:
- transmitting low-frequency LF signals via the 125 kHz power amplifier block
- receiving radio frequency RF signals (> 300 MHz) from the built-in ISM receiver block
- encrypting and decrypting all relevant data signals (security)
- communicating relevant interface signals with other electronic control units
- microcontroller
Inside Outside detection
The smart key determines if it is inside or outside the vehicle by measuring the strength of the LF fields. In order to start the vehicle, the smart key must be inside the vehicle.System reaction times
The mark of a good passive entry system is that the user never hits the "wall". This happens when the user pulls the door handle to its full extent before the door is unlocked. The handle has to be released and pulled again to gain access. Good systems have an override feature that allows the doors to be opened more quickly.Security requirements
It is important that the vehicle can't be started when the user and therefore the smart key is outside the vehicle. This is especially important at fueling stations where the user is very close to the vehicle. The internal LF field is allowed to overshoot by a maximum of 10 cm to help minimise this risk. Maximum overshoot is usually found on the side windows where there is very little attenuation of the signal.Relay Station AttackA second scenario exists under the name "relay station attack" (RSA). The RSA is based on the idea of reducing the long physical distance between the car and the regular car owner's SmartKey. Two relay stations will be needed for this: The first relay station is located nearby the car and the second is close to the SmartKey. So on first view, the Keyless Entry / Go ECU and the SmartKey could communicate together. A third person at the car could pull the door handle and the door would open. However, in every Keyless Entry / Go system provisions exist to avoid a successful two-way communication via RSA. Some of the most known are:
- measuring group delay time to detect illegal high values
- measuring third-order intercept point to detect illegal intermodulation products
- measuring field strength of the electric field
- measuring the response time of 125 kHz LC circuit
- using a more complex modulation (i.e. quadrature amplitude modulation) which can't be demodulated and modulated by a simple relay station
- ESCL Electric Steering Column Lock
- EIS Electronic Ignition Switch
- Central door locking system
- Immobiliser
- Engine Control Unit (Motor management system)
- BCU Body control unit
Internal LF field dead spots
Dead spots are a result of the maximum overshoot requirement from above. The power delivered to the internal LF antennas has to be tuned to provide the best performance i.e. minimum dead spots and maximum average overshoot. Dead spots are usually near the extremities of the vehicle e.g. the rear parcel shelf.Battery Backup
If the battery in the smart key becomes depleted, it is necessary for there to be a backup method of opening and starting the vehicle. Opening is achieved by an emergency (fully mechanical) key blade usually hidden in the smart key. On many cars emergency starting is achieved by use of an inductive coupling. The user either has to put the key in a slot or hold it near a special area on the cockpit, where there is an inductive coil hidden behind which transfers energy to a matching coil in the dead key fob using inductive charging.Slots have proven to be problematic, as they can go wrong and the key becomes locked in and cannot be removed. Another problem with the slot is it can't compensate for a fob battery below certain operating threshold. Most smart key batteries are temperature sensitive causing the fob to become intermittent, fully functional, or inoperative all in the same day.
Special Cases
A Keyless Entry / Go system should be able to detect and handle most of the following cases:- SmartKey Transponder was forgotten in the rear trunk
- More than one SmartKey is present inside the car
- SmartKey getting lost during the drive
- Smartkey battery low (Limp-Home)
History
The first Keyless Entry / Go ECU of the MB S-Class car series 1998/99
The system is based on a technology invented by Siemens VDO called PASE: Passive Start and Entry System. It operates in the ISM band of radio frequencies. Keyless Entry / Go was introduced first by Mercedes-Benz in the S-Class car series in 1998.
Outlook
Today a Keyless Entry / Go system is a state-of-the art technology and still has a lot of potential to optimise. Here are some general trends of the advance (AD) and series development (SD):- SD: reduction of used LF antennas in low-cost compact cars (results in a loss of detection quality)
- AD: using electric field antennas instead of magnetic field antennas (cost reduction)
- AD: using microwave frequencies (radar) instead of an LF and RF combination (more comfort)
- AD: Biometric authentication would identify the user and not the SmartKey transponder
Effectiveness
A test by ADAC revealed that 20 car models with Keyless Go could be entered and driven away without the key. In 2014, 6,000 cars (about 17 per day) were stolen using keyless entry in London.https://www.motor1.com/news/365690/k...bility-tested/
Some cars can be stolen in seconds.
Keyless cars provide huge convenience for owners and drivers alike, however, they also make stealing cars considerably easier as well.In a matter of seconds, criminals can take keyless cars by using a device to relay to signal from key fob in the house to the car, allowing them to open the car, start it, and drive off.
Car thefts in England and Wales are currently at an eight-year high – last year alone, 106,000 cars were taken.
Now What Car? magazine has tested seven new cars all equipped with keyless tech to see which are the most vulnerable to theft.
Mercedes-Benz A-Class
Get into car
Drive Away
Keyless-Go key fob inactive
Not possible
Not possible
Keyless-Go key fob active
30 seconds
20 seconds
As well as Audi, BMW, Ford, and Mercedes-Benz have all introduced motion detection technology for their keys, which disables them if they remain untouched and not moving around. When the keys were deactivated, the cars couldn't be taken in the What Car? test.
https://www.locksmiths.co.uk/faq/keyless-car-theft/
Find out what Keyless car theft is & how to prevent your keyless entry car being stolen. Learn if your car is keyless entry & what car models are at risk as keyless car theft (relay theft) is a crime on the rise. As the UK’s largest trade association for locksmiths, many of our members are auto locksmiths so have knowledge with car keys and locks.
Keyless Entry Cars Tested Against Keyless Car Theft by Thatcham
In 2019 Thatcham launched a security rating for keyless entry car models and how they performed against relay theft, below are the results.PASSED Vehicle Models of Keyless Car Theft Test
The following keyless entry car models PASSED Thatchams relay attack test and were given a superior security rating:Mercedes B-Class Passed Superior Security Rating
Ford Focus, Fiesta, BMW, Audi & Mercedes have introduced Motion Sensor Key Fobs. A Motion sensor car fob will go into sleep mode after being inactive for 40 seconds, which prevents any criminals from getting the cars signal.
In these infinite size keychain scenarios, the Ticonn pocket case I noted above (post #47) will accomodate only a minimal setup that would permit the case to be closed. The larger and bulkier the keychain, the less likely you can close the flap to attempt a "Seal." Beyond that, the main issue of reliable signal blocking is very problematic.
The alternative that really works is the ability to turn off the Smart Key itself. I think this capability is only available with some MYs of facelift cars (2014+) with the Keyless Go option. My 2016 keys can be turned off, and I think several folks here have tested their keys for the same function, with limited success.
The system works by having a series of LF (low frequency 125 kHz) transmitting antennas both inside and outside the vehicle. The external antennas are located in the door handles. When the vehicle is triggered, either by pulling the handle or touching the handle, an LF signal is transmitted from the antennas to the key. The key becomes activated if it is sufficiently close and it transmits its ID back to the vehicle via RF (Radio frequency >300 MHz) to a receiver located in the vehicle. If the key has the correct ID, the PASE module unlocks the vehicle......
I am still skeptic.
My car will activate trunk lock without me touching it.
So the above gives no clue how it works.
Plan to use the case to keep the FOBs in all the time (in the house, etc.), so solves both issues (hopefully). Thanks for bringing this to our attention!
FYI, I have 2 Faraday bags and only keep an MB key fob in each one (i.e. no additional keys to fill it up). Alternatively, you can order a Faraday bag sized for a smartphone and use it to carry Keyless Go fob + house keys:
I use the latter for my smartphone when traveling abroad.
- Longroof
FYI, I have 2 Faraday bags and only keep an MB key fob in each one (i.e. no additional keys to fill it up). Alternatively, you can order a Faraday bag sized for a smartphone and use it to carry Keyless Go fob + house keys: Faraday Bag, Wisdompro RFID Signal Blocking Bag Shielding Pouch Wallet Case for Cell Phone
- Longroof
I believe the rectangular fobs on the newer models (all are dedicated Keyless Start, some are Keyless GO) have the same off/on feature, or they that they automatically turn off on a timed basis.
(Image from eBay listing)
I have an older Sucrets box around here, somewhere. Holding small screws in a drawer in the garage, I think. Time to look around... edit: Sucrets box not found.
I have already tried a metal airgun pellet box, and it doesn't work.
Cannot get in car and Thief cannot get signal.
No need for cage then.
Out to dinner and car on street out front... turn key off thief cannot steal..
Unfortunately, without modification, the key within will unlock the door, so it's a fail. I then removed the fob, wrapped it in a paper napkin to isolate it from touching the inside metal, and it still failed to isolate the key. Maybe some felt?
Here's what I bought, and again a Thanks to DFWdude for bringing this to light and the multiple trial and error tests done by him, and others here...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
When I am not paranoid about thieves with repeaters stealing my car at McDonald, I often notice that when I bend my knees working around the car, the buttons get pressed in my pocket. Had incident when I was checking something around the car with passengers in it.
Accidental button pushing locked the car and when passenger open the door- the alarm went off.
The way the repeaters work, it doesn't matter if the key is off until the car wakes it up, the repeater just sends the car's signal to the key to wake it up so that it sends a code and the signal gets repeated near the car. When the key fob just shuts off, a signal from the car doesn't wake it up.
10 (or 30) minutes later you are getting emergency call that the car doesn't start.
Than 5 minutes is more time than thieves need to pull your car from front of McD.
I am getting such calls from our friend. He is guy who runs a bussines of designing computer boards and always denying the fact of his phone is making pocket calls.
I use my android for hiking distance tracking and in the past was always waiting for the screen to go black before I put it back in the pocket. Took me 3 years to find out that pushing power button makes the screen goes black on instant.
Than 1 time my android program itself with password for opening. Since I had no idea what password it was, I had to reboot android, wiping all the data from it.
