Sponsored by: CARiD
Replacing Front Diff Fluid - how to?
Old Oct 7, 2019 | 07:00 AM
eahearn's Avatar
2015 ML250D, 2024 VW Golf R
Hi, 2014 E350 Fourmatic - mechanic can't figure out how to drain the fluid from the Front Differential to replace it. Anyone know how?
Thanks!
Old Oct 7, 2019 | 07:57 AM
RA72825's Avatar
Can’t drain the transmission? Not sure I understand. The two are integral
Old Oct 7, 2019 | 08:32 AM
eahearn's Avatar
Thanks! That’s what I was looking for.
Ed
Old Oct 7, 2019 | 09:27 AM
konigstiger's Avatar
'71 Pinto
Unless I misunderstood the question.
Old Oct 7, 2019 | 10:24 AM
eahearn's Avatar
Thank you. So just to confirm, you agree that the transmission and the front differential are integral and that they share the same fluid 😀?
Old Oct 7, 2019 | 10:49 AM
'71 Pinto
No, separate see 221 diagram shown same a 212.
File Type: pdf
Old Oct 7, 2019 | 10:54 AM
eahearn's Avatar
Thank you very much
Old Oct 7, 2019 | 01:20 PM
cetialpha5's Avatar
This is covered in a few other threads. But how was he planning on filling it? I forget where the fill hole is if there is one. Sometimes they just fill it through the same drain hole but you have to have the right sized tubing to fill it. As you can see from the approved fluid list, there are very few fluids that meet spec aside from the MB fluids. I believe it's just a small amount so I just buy it from MB.
Old Oct 7, 2019 | 03:16 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
The PDF konigstiger attaches explains filling procedure.
My first impression on this thread is that when your mechanic has such problems - it is good time to look for different mechanic.
Old Oct 8, 2019 | 05:29 PM
atraudes's Avatar
2011 E350 Wagon, 2010 GL450
FWIW, the fill adapter you use for the transmission works perfectly for the front diff too. Agreed, make sure he understands the implications of filling it before he drains it.
Old Oct 8, 2019 | 06:42 PM
eahearn's Avatar
That’s for sure...
Old Oct 9, 2019 | 11:03 PM
MBNUT1's Avatar
2010 E350 4Matic
Old Oct 12, 2019 | 01:01 AM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
At what mileage, the front diff fluid needs to be changed ??
I have never change it before.... LOL
Old Oct 12, 2019 | 09:28 AM
'71 Pinto
IMHO coordinate with transmission oil/filter change. In your case (278) every 70,000/7-years whichever comes first.
Old Oct 12, 2019 | 09:06 PM
cocobeex's Avatar
THANK YOU AGAIN!!! I will do it in the following week.
Old Jul 30, 2021 | 10:03 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Did both diffs on the E550... rear was easy and the fluid looked fine at 100k. The front, on the other hand, was looking past due. Drained the front diff into a measurement cup and collected 16 oz. Per WIS, it should hold 18.6 oz and its had a slight leak since the PO (10 yrs, 100k some loss for sure).
I used a transmission filling adapter (same as 722.9), short piece of hose, fluid pump and quart measuring cup. To account for some waste from spillage and oil remaining in the line/pump/cup... I started with 20z and ended up putting in close to 18 oz. Similar technique to this: https://mbworld.org/forums/s-class-w...il-change.html
Used oil out of rear diff
used oil out of front diff
So, moral is... change the front diff oil sooner, maybe 50-75k. I'm curious what it'll look like in our E350.
Attached Thumbnails Replacing Front Diff Fluid - how to?-img_4893.jpg   Replacing Front Diff Fluid - how to?-img_4897.jpg
