Center console trim strips and bezel around A/C part numbers needed
Currently, on my W212, factory-installed is the metallic trip strip that I am not liking whatsoever. I have the "TRIM PIECES - WOOD ASH BROWN" package and I find the metallic trip strip a distraction:
Also, the bezel surrounding the Automatic air conditioning control and operating unit is in black and I am looking for the WOOD ASH BROWN like this:
Wondering if any knows if they fit my 2016 W212 along with the part numbers for both the left and right trip strip along with the bezel surrounding the Automatic air conditioning control and operating unit?
Also, if someone knows who sells them online, I'll be very grateful as I tried looking but to no success.
Received 4,435 Likes
'71 Pinto
VIN? Need to confirm interior wood trim code before exploring part availability.
'71 Pinto
Trim
Left 2126907982, right 2126908082
Cover
2126802407
Need to check with MB dealer parts to see if these parts #s are currently available in H09 “wood ash brown”. And if so, note replacements may not match perfectly with existing trim.
Cover
2126802407
masads (10-08-2019)
I rang up the MB dealership parts department and they are requesting a VIN number who currently has these parts mentioned by konigstiger. I am not sure where I can get this info as when I provide my VIN, the trim pieces are metallic and the bezel is black. The screenshots I had provided in my initial request are from Google.
Got a VIN that has these parts installed by the factory (2013 MB E350)
Rang up the dealership and provided the VIN that has the parts. As per the parts department, the numbers are "very different" than what I have in my car. I.e. from konigstiger Left 2126907982, compared to what they have in their system 2126906562 (H09) both are Left trim. And, Right 2126908082 compared to 2126906662 (H09). Same for the Cover Operating Unit, Heater and AC, konigstiger mentioned 2126802407 and they gave 2126807607
So they were not sure if it will fit without me paying for them. If they do not fit, I do not have the ability to return them as these parts are not based on my VIN.
How can I confirm?
How can I confirm?
Can you order them and inspect them in person before paying? You could pull the trim pieces off your car and bring them in with you and compare them side by side.
Also, I'm sure it's the "grass is greener" phenomenon, but that silver and black looks really good! Would you be up for selling them once you're done? If so, how much?
'71 Pinto
Originally Posted by masads
I was just wondering if you had instructions on how to replace the side trims?
masads (10-15-2019)
Masads did you ever replace the Aluminum look console trim pieces? And does anyone know are these two trim pieces interchangable between <2013 & 2014> W212 models? Conversely I have wood and prefer the aluminum look.
bmdaia, no I did not change the aluminum trim pieces as I did not want to take a gamble in ordering it and then finding out that it might not fit.
