Drl daytime
2014 e250, facelift, partial led headlights
Should be in this position:
https://i.ebayimg.com/images/g/xewAA...v6/s-l1600.jpg
I'd remove the wiring splice for the grille star at the DRLs, reseal and wrap the former splice area thoroughly with waterproof materials, and then retest your DRLs. Hopefully the DRLs will then return to normal.
Just to clarify, I have not tapped into any wires, and no splicing done. Even before I got the star I noticed the following conditions with the DRL lights:
- DRL's come on always during evening/night time when unlocking/locking. DRL's stay on with headlights.
- DRL's do not come on during daytime when unlocking/locking the car. Have to manually turn the light switch to one notch left and then the DRL's are on only.
FYI: I have partial LED lights, not full.
In countries where DRL availability is required, the City Lights are not triggered as DRLs via the sensor. Instead, they will light whenever the ignition is on (night or day), and the light switch is set for Auto.
Thanks for the clarification. All of your other lights work as normal -- via the sensor -- as you describe. In this case, the "DRLs" are just the normal "city lights" or "parking lights..."
Yes, I am in Ireland. I don't know about the DRL laws here but I had 2011 BMW 3 Series before this and the DRL's on that car would remain on regardless of time. Maybe its how they were manufacturer coded.
I guess, if that's how they came, they will have to stay that way. Pity, Mercedes cannot be coded using a "Carly" adapter like BMW's.
We we all know this and these lights should come on at daytime. The purpose of these lights is to make car visible to other road users and are very helpful when car drives with low sun behind or in a dark shadow. The lights have been made extra bright and to emit light in wide angle for the best visibility.
Because of the type of the light used DRLs should NEVER be on at night with full power so I’m thinking someone changed the coding for the lights as they seem to work opposite from the darkness sensor.
If someone used the DRL wire for triggering that star light he made a big mistake. Should have used parking light or the head light wire for that purpose.
My car has DRLs that stay on at all times but when head lights come on the DRLs dim down to 20-30% power and do not cause problems for on-coming traffic in dark. I have read that newer models have them turn completely off when head lights come on but I think in those cars the coding could be changed to keep them on at low power. Makes the car front look good in dark.
