Rear SAM failure on 2014 E350 wagon?
We have a 2014 E350 wagon. Today, a few things on the car stoped working, and surely they're related:
1) The two inner tail lights that go on the tailgate don't power up (same for the built in reverse lights), however the outer lights on the body of the car do power up. This car has the LED intelligent package, if that's relevant.
2) The handsfree power liftgate won't activate via a foot kick under the bumper
3) When the car is locked, the tailgate latch won't open the tailgate, however if the car is unlocked first, the tailgate latch will open the tailgate and it will raise under its own power. It sounds like the KEYLESS GO in the back is affected.
4) The tailgate will close when the power liftgate button is pressed, but it doesn't latch at the bottom. It's actually loose and you can wiggle it.
I believe that the rear SAM controls all this. This all sounds like more than just a blown fuse, though. Is it likely that the entire rear SAM module needs to be replaced? I appreciate any insight or ideas you all have.
Thank you!
The rear SAM controls many many things and it appear that it didn't fail wholesale, but just things relating to the liftgate. What do you all think?
Thanks all!
