Acoustic lock stopped working after horn change
The horn went bad due to heavy rain. It was very rainy and there were many ponds of water. The Low frequency horn went out because its hole was pointed towards the bumper so water could easily enter. The High frequency horn on the other hand was at a better position so it was more water resistant. Sorry I forgot to mention, but the acoustic lock is already enabled in the car. I did try to deactivate then activate it but no luck. I also tried to deactivate, drive the car for a while, turn it off, then I activated once again and drove for several miles again and then I locked it to test the acoustic lock but still no luck. I don't know what to do and even my mechanic has no idea.
With latest SCN-frenzy ideas, I wonder if the horns might have module that require coding, or pairing.
BTW I forgot to mention, My mechanic was changing my brake pads at the same time he was changing my horns. I don't know if they are related or no but I thought it's worth mentioning. Also, I mentioned this before but I want to stress it, after the brake job and the service in general, I reinstalled my old horns (one was working and the other not) and the acoustic lock was also not working! So is it related? I will try disconnected the fuses as suggested by konigstiger
P.S: I pulled out the relay and fuse while the car was off, is that how am supposed to do it?
I was disconnecting the car for vacations who were planned for 3 months, so I pulled the battery on garage floor and hooked up maintainer on it.
