Brembo rotors and pads.
Emailed BremboUSA and was asked for pictures. Sent them, and it's been over 48 with no response.
And the surface is fine, is the indentations on the surface that worries me. It is supposed to be porous for it to bite.
I have ordered brake discs before and never have I seen this, so I was a bit confused.
The Zimmerman in the vid look like Pagid with it's silver coating and it isn't robust , on a modern car with nice alloys , silver discs and silver lumpy bumpy cast calipers look vile as they detract from the glory of the wheels .
Even with Brembo's dark metallic coating I abrade and spray black smooth Hammerite for a never rust unswept areas .
that is where i got my Brembo set from.
Good luck
JP
even though , there was a thread about it and there was a member that somehow found solid rotors without drilled out holes and he was happy with them. I wonder where hes got them and if they still dont vibrate.
Really hate to have it on a benz.
I tried multiple rotors .... but i gave up.lol
The Brembos are working good. The pedal feel is lot more linear than when the Zimmerman's were with Brembo semi metallic pads. Stop pretty good at high speed too (130+). I am waiting for the bed in coating to wear off to see how dust is.
Also I'm not sure high speed and medium speeds are the proper way to bed in new pads. You're supposed to drive moderately and I don't think high speed counts as moderate. High speed probably means high heat and if you have your foot on the brake with hot pads it's more likely to stick to the rotor giving you that warped feeling...
https://www.tirerack.com/tires/tiret....jsp?techid=85
Please let me know as this is the combo i am currently eyeing.
Thanks.
It's been 4 years wow. Same pads and rotors finally gave up. 45k miles I believe, may be more. 160+ MPH stops repeatedly, and reliably. The dusting was insane, but the rotors never warped,
Just got another set, but this time I went with a different pad same rotors. Just did some heavy holiday stop and go traffic, and hard 160+ stops, the dusting is almost non-existent.
Pedal feel is a bit more linear, it is taking a little longer for them to bed, but no squealing, or weirdeness on the brakes. Panic stops are good.
I could have possibly resurface the old rotors, but I let them get glazed, they were getting hotspots in the last month I had them (totally my fault). They went from perfect to bad, in the last month.
They really put up with my driving.
Please for the love of god very important, do not let ANYONE work on your brakes with an impact gun. If you see an impact gun anywhere near those brakes, take the car somewhere else. These calipers are made of aluminum/aluminium , and one wrong torque setting, and it's helicoil time.
Power Stop Z26-1634 Z26 Front Carbon-Fiber Ceramic Brake Pads
