A few pics and a few questions...
Old 02-12-2020, 10:32 AM
cetialpha5's Avatar
Received 1,503 Likes on 1,174 Posts
It's pretty close, just doesn't cover cosmetic things which is what the faded wood is.
Pre-safe inoperative would probably be covered.
No idea about your keyless go control code, you'd have to say where you read that. Don't know that it has anything to do with the dealer. You only need to remove the button if the battery in your key fob is dead and you can't start the car. Once you put it in the ignition, it will start the car because it doesn't need a battery.
Old 02-12-2020, 10:49 AM
KEY08's Avatar
Received 1,625 Likes on 1,192 Posts
2014 E550-sold 😩
The keyless go button is just a piece of plastic. It is not specific to your car, has no electronics and can be bought all day on Ebay if you lose it. As Cetialpha5 has indicated you can enter the car with the blade key and start your car with a completely dead fob by inserting it into the key slot once removing the push button with your fingers. The car will never leave you stranded.
Ask you dealer for a copy of the CPO certificate with the coverage. The file is too large for me to post up here for you.
Old 02-15-2020, 09:56 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Originally Posted by mtnman82
Now for some questions...
Twice today while driving, once in the morning and once again this evening, with no one in front or behind me I heard a 'beep beep' - as in two quick beeps. The second time I thought I caught a red triangle flash between the fuel and temperature gauges. I'm wondering if this was the collision prevention assist going off and if there isn't something wrong with it? Is there a log of this I can access? As I said - driving down a straight level road with no one around me, front or rear
This car seems to run with the temperature gauge right at 90 degrees Celsius, which puts the needle above horizontal. Is this the normal operating temperature?
I've already read there is no way to set the car so that ECO (start/stop of engine at a stop sign or stop light) will stay off. Anybody using the Mid City Engineering device to keep it off?
I also noticed that if I put the car in sport mode it will revert to economy mode when I start it back up again?
The tray cover over the cup holders and lighter/ash tray... Is this supposed to close all the way by itself? Mine sticks half way over the cup holders - I have to finish closing it by hand.
Here are my answers - I own the same car.
Random beep-beep - Collision Prevention Assist Plus false positives. Happens to me, too, but not consistently. Maybe twice a month.
Temp gauge - this is normal operating temp. Mercedes decides to give it to you straight instead of making it just default to the middle. Was your W203 not like this? Mine was.
You can software program this to start in S mode, but yours works as designed. Note that S mode locks out 7th gear.
The ashtray/cupholder cover. If you push it all the way open, then push it once it should stop leaving the cup holders exposed but ashtray covered. Pressing it again it should close completely without help from you. It slows down a bit and closes gently. If you have to help it at all, it's broken. This will be covered under factory warranty so go get this fixed.
You wisely avoided a car with fading wood trim. You have the dark ash wood, this should not fade.
The E350W is normal. My C230 was always "C230WZ" for some reason.
Your PRE-SAFE message is probably voltage related like was suggested earlier. Does your car do the eco start/stop a lot? I noticed mine stopped working and the engine never shutoff. That was the first sign for me that the battery was weak. They should replace it under warranty. I would find someone else to talk to since your guy thought it had something to do with sensitivity settings. Yikes.
Old 02-15-2020, 06:02 PM
El Cid's Avatar
2010 E350 Luxury Sedan, Engine 272 (V6)
Originally Posted by KEY08
90-92c is normal. Console door has a stop to cover the ash area. Push it all the way forward from the ash stop and release. It should then close completely
and stop spinning the tires causing a traction alarm. Lol
Mine is the same, but it is a matter of how often you use it. I seldom open mine, so it is always slow closing or I have to pull it to get it all the way.
[QUOTE=DFWdude;7977827]
As for the Stop/Start feature, I've placed a small sticker on the seatbelt assembly to the left of my driver's seat. It reminds me to turn ECO Stop/Start off when I fasten my belt.
REPLY
As for Stop/Start, that is on my list of features to avoid if at all possible. Every time I get a loaner from the dealer the S/S bugs the heck out of me.
[QUOTE=mtnman82;7977870] I have 15 months of warranty but was hoping to only use it once or twice for little things like the emergency brake not popping up all the way...
REPLY
You paid for the warranty when you purchased the car, use it. The dealer won't care, because he makes money off it. This forum is a great place to learn about things that you should have the dealer check out as long as under warranty.
I called my sales guy about the PRE-SAFE Inoperative
If you have a service question, call the service department or service manager/director. The salesman got his money, he could care less at this point. He is working on selling cars, not taking care of customers.
Old 02-15-2020, 10:56 PM
jonUF02's Avatar
2015 GL550 4matic
If the ash tray cover piece is really messed up, there are plenty of used ones on Ebay. Color does not matter since you can easily take off the fake wood parts and swap them over.
I was going to say someone who has a dealer type Star computer and is proficient with it could probably lock out the stop engine feature. Look for a good indy shop or just a guy on local classified ads promoting MB computer diagnostics. It seems there is a service from the Carplay guy for it. I would find it endlessly annoying. I don't set Sport mode most of the time because I do mostly city traffic driving and I just want the comfort mode.
Old 02-16-2020, 12:06 PM
El Cid's Avatar
"Fake wood parts?" They are wood, that is why they are more subject to fading.
Old 02-16-2020, 08:49 PM
  #32
ghlkal's Avatar
2012 E550 v8-Biturbo
Wait, I've never heard or read that before. From what I've read, E starts in 2nd gear and shifts are slower, while S starts in 1st gear with faster shifts.
Do you have any reference for locking out 7th?
Old 02-16-2020, 09:00 PM
  #33
95Sinned420's Avatar
2016 S550
E starts in first, for those with the annoying start/stop tranny.
Old 02-17-2020, 04:14 AM
  #34
LILBENZ230's Avatar
Actually my info may be incorrect. It locks out 7th at under 50. I’ve never driven in sport mode on the highway but I am hearing that once you’re at highway speeds even S will shift to 7.
All 2014-2016 E350 and E250BT models start out in 1st gear regardless of whether you’re in E or S. Apparently the more powerful cars like the E400 and E550 start in 2nd in E mode.
Old 02-17-2020, 07:48 AM
  #35
KEY08's Avatar
2014 E550-sold 😩
wrongo. My ‘14 E550 4M starts in 2 when in E mode and 1 in S mode. Yes, I have Eco/ss
Old 02-17-2020, 08:01 AM
  #36
DFWdude's Avatar
Received 1,755 Likes on 1,125 Posts
2016 E350 Sport
As I read it, I believe LILBENZ230 has stated exactly what you have...
I don't understand why there is so much back and forth on this thread?
Old 02-17-2020, 10:50 AM
  #37
KEY08's Avatar
2014 E550-sold 😩
Thank you for clarifying the clarification with another post.
Old 02-17-2020, 05:51 PM
  #38
nota_amg's Avatar
2013 SL550 BiTurbo
My 2012 E550 always starts in 1st, in both Sport and Eco mode. Also, you CAN shift into 7th when in Sport mode, you just need to hit the upshift paddle...I do it all the time, Sport mode, in 7th, below 50mph. On the highway it will shift into 7th on its own.
Old 02-18-2020, 01:05 AM
  #39
mtnman82's Avatar
'16 E350, gone: '03 c230k
My 2016 W212 starts in 1st in both E and S modes. My W203 (5-speed tranny) started in 2nd in C mode and 1st in S mode.
Sat at the dealer all day today. 2+ hour drive to get there. When I started the 'PRE-SAFE Inoperative' went off ~6 times in the first 5 minutes of driving. They couldn't duplicate the issue. They did update the software for the Collision Assist. No PRE-SAFE or false Collision Assist on the way home. Keeping my fingers crossed. They also fixed or ordered parts to fixed a number of small things. They also updated my COMAND software to resolve various Bluetooth issues.
Old 02-18-2020, 07:43 AM
  #40
DFWdude's Avatar
2016 E350 Sport
Oh boy... My 2001 C320 is a top-of-line W203 with every bell and whistle available, short of the AMG model. I am the original owner, since May, 2001. It is a 5-speed Automatic (all that was available on the C320). There are two transmission modes available, "S" for Standard, and "W" for Winter. In normal driving ("S") mode, this car ALWAYs starts from a stop in first gear, ALWAYS. On the rare occasion when there is snow on the road, my owner's manual (pg 252-253) says I can minimize wheel slip by switching to "W" (for Winter) mode. In W mode, it will pull away from stop in 2nd gear. In "S" mode, it NEVER starts out in 2nd. All of this is explained in the W203 manual, which I have consulted for 18 years now..
Ah, good for you...
Old 02-18-2020, 08:29 AM
  #41
LILBENZ230's Avatar
How are you liking the W212 so far?
Old 02-18-2020, 08:51 AM
  #42
DFWdude's Avatar
2016 E350 Sport
deleted dupe
Old 02-18-2020, 08:52 AM
  #43
DFWdude's Avatar
2016 E350 Sport
Your question is for mtnman82, right?
Old 02-18-2020, 09:10 AM
  #44
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
I'm going to need to adopt this statement, lol!
KEY08 (02-18-2020)
Old 02-18-2020, 09:39 AM
  #45
mtnman82's Avatar
Yep DFWDude my friend, I was agreeing with you on the W203 staring out in 2nd while in 'W' mode. I misspoke when I said 'C' mode, which was just a vernacular change for the later W203's, same functionality. Also agreeing with you that my W212 always starts in 1st gear regardless of mode.
Digging the W212 so far. After having put quite a few miles on the road now I could see wanting a bit more on the power side but overall it's really not lacking. The few times I was looking for a bit more were excursions 90% of drivers probably wouldn't be taking. If it weren't for the PRE-SAFE and collision assist issues I'd be totally enamored. The service guy was really good, very helpful and accommodating. Really really hoping we can get the few kinks worked out and then log many many years of reliable service.
Old 02-18-2020, 10:27 AM
  #46
KEY08's Avatar
2014 E550-sold 😩
I'm in that 90%.....
I have taken the beast out onto Road America even, just to see what it is capable of. ha
Old 02-18-2020, 11:08 AM
  #47
LILBENZ230's Avatar
I'm surprised to hear that about the power.. I figured compared to the W203, the W212 even in 350 form would seem like a rocket.
I wonder what is really going on with the PRE-SAFE thing? I would have guessed weak battery. Mine has had no issues aside from a couple of false warnings, but all collision warning systems do that.
Quick Reply: A few pics and a few questions...
