Sponsored by: CARiD
Need help with wheels
Old May 5, 2020 | 04:56 PM
Petrol 2011's Avatar
E350 2011
Hello, i just bought 2011 w212 sedan e350 4matic. With 677 avantgarde/standart suspension with original 18’’ wheels 245/40 tires. I want to put on 19’’ or maybe 20 inch.
Is it possible to put on this car some kind of this wheels and what ET and J and all tire parameters i should choose on each option?
Old May 5, 2020 | 05:48 PM
nota_amg's Avatar
2013 SL550 BiTurbo
I run 19x8.5 +32(front), and 19x9.5 +39(rear) on my 2012 E550, with 245/35 and 285/30 tires respectively. My wheels are very flush with fenders.
Old May 5, 2020 | 05:59 PM
E350 2011
Is you suspension stock? Standart?
Is it OK to have different wheel width on 4matic?
Old May 5, 2020 | 06:48 PM
RA72825's Avatar
I have 19 x9 E63 AMG wheels up front ET37 with 245/35 tires. 19x9.5 in back, ET50 with 285/30 tires. I have 4Matic and this is not an issue as the rolling circumference is under 1% difference front to back.
Old May 6, 2020 | 10:13 PM
Quattrodude's Avatar
2011 E550 - 4Matic, 2008 ML550
Ill send you pics of my new 18x8.5s ET35 all the way around - I have 4matic - on Friday!
Crossing my fingers i made the right choice...
(even if the pic is with my back end sagging - still dealing with Airmatic woes)
Old May 7, 2020 | 02:56 PM
E350 2011
Does your amg have same 677 suspension?
Old May 7, 2020 | 06:28 PM
RA72825's Avatar
my model is an E550 4M and I am on springs. Yes 677 suspension
Old May 8, 2020 | 04:05 PM
nota_amg's Avatar
2013 SL550 BiTurbo
Yes, I have stock standard(spring) suspension that is at stock height. I have some lowering springs, but I don't think I can lower it with the 285's in the rear without them rubbing...MAYBE with some extra negative camber dialed in, but I wouldn't could on it. Wish I could out more tire on it though (like maybe a 305?)...having traction issues with my new custom tune, even WITH 4matic...😁
