Sponsored by: CARiD
DRL
Old May 12, 2020 | 03:18 PM
BoroGunner's Avatar
E350
DRL
Hi guys Does anyone know how I can remove my DRL on my E Class 2010, as I’m going to try to fly mesh wrap them, pictures or video help ideal
Old May 14, 2020 | 03:49 AM
Peachy's Avatar
2010 E550
If you remove everything from behind it like the wheel, fender liner, and gravel shields you can see the screws and clips and stuff on the other side.
Old May 14, 2020 | 11:20 AM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
Old May 16, 2020 | 04:40 PM
Quattrodude's Avatar
2011 E550 - 4Matic, 2008 ML550
Expect to spend some time getting them out and back in - its not a 20 min job...Take your time- you do not want to break any tabs
Also - you will want consider taking out the whole housing as its much easier than trying to squeeze it from the housing....You will understand when you pull it apart.
Not sure why fly mesh is? Maybe you mean blacking them out?
Me I like the hockey sticks..
Good luck!
