Transfer Case Leaks Fluid 2012 W212
R230 SL65 $ W212 E350
Anyone on here having the same problems with the W212 models! The transfer case is leaking oil! The transmission has no vibration and shifts are smooth! I can’t see if it's the housing itself or the front driveshaft seal has failed! The car has only 72k miles on it! Service records up to date, including tranny flush 2 years ago!
Received 4,435 Likes
'71 Pinto
See attachments to explore repair.
Thanks for the attachment! Does the entire case need to be rebuilt or just the bearings and the seals?
Ty
QUOTE=konigstiger;8066485]See attachments to explore repair.
[/QUOTE]
Ty
[/QUOTE]
'71 Pinto
Most likely seals, only inspection will answer your question.
