(video) Replacing Bio-functional Cabin A/C Filter for W212
This is not the first time to try the Bio-functional cabin filter, I used to install it in my W221(S550). The effect is not bad.
If you like my video, subscribe to it.
The following 5 users liked this post by 39039:
darkshinobi (05-27-2020),
dbldpr (05-12-2020),
mercy-me (04-30-2020),
pierrejoliat (05-17-2020),
Sactownmb (05-03-2020)
This is the one I just installed on my E350. Came from FCP. What is special about this filter?
Also does anyone know what the sensor is that you have to pull out?
39039 (05-02-2020)
I am satisfied with the Mann's bio-functional filter. That was last two years without odor and pollen due to the PM2.5 grade and activated carbon. I have no experience with Bosch filter. As my opinion, Bosch is good at electronic of vehicle but not in the area of auto consumables.
The following 2 users liked this post by 39039:
ml3504matic____ (05-17-2020),
39039 (05-21-2020)
Great video!
I don't know how you managed to slide in the new filter so easily? I used a bosch replacement filter (1987435001) recently and I had to shove it real hard before I could reseat the white slider.
I guess I'll buy that Mann filter next year instead.
39039 (05-21-2020)
Received 4,553 Likes
Since I am right hand drive/steering, I must order this from UK. FP 29 005/1
https://catalog.mann-filter.com/EU/e...P%2029%20005~1
Dang..been hunting it down locally since last year, could not get it.
39039 (05-21-2020)
Since you’re going to take the panel down and be in the filter housing anyway - might as well use a can or two of Kool-it to wash out the evaporator coil while you’re there. I’ve done this once a year for the last 3 years (right as ac season starts up) and it makes a huge difference in air quality in the car. There are YouTube videos on it, specifically for the W212 (it’s extremely easy). If you want to see how gross your evap coil can get after a year, just look under your car as the kool-it is draining out of the drain tube and taking the funk out of the coil fins with it. Amazon for about $10 a can. One should do, but two will totally do it without any doubt.
39039 (05-21-2020)
2014 E350 4M Diamond Silver
Just FYI, if you haven't saw that thread.
https://mbworld.org/forums/e-class-w...c-systems.html
39039 (05-21-2020)
39039 (05-27-2020)
