E550 Mystery Reservoir
What is it, and what goes in it?
I run wet wetter in mine, keeps AIT's low!
I drained my little tank and added Water Wetter, and I can't tell the difference
Next stop is draining it all and replacing with maybe 80-90% water and the rest Propylene Glycol, just for pump lube and rad protection. Or maybe Water Wetter, who knows.
I was thinking the bennie might be more about better flow than heat Xfer, but all that matters is if it helps or not.
Also considering water misters in front of the rad, which I think would be awesome. I already have the stuff to do it, except one very important thing; motivation...
The pump for this system has a short life span, but varies. Hard to say but maybe 3yrs to >5? That's based on people who have replaced them, and post about it, but my guess is many/most are unaware it has died. The car will not tell you, so might want to check. It's hard to tell since it only comes on when air gets really hot, but you can jumper it to force it on, or "see" it if you data log. To data log you floor it and the the air temp should drop, then rise slowly and not go very high. How high? I guess maybe 20F but it varies on ambient temp and how long you floor it for. If it climbs to like 130 or more then I'd assume the pump died. You can data log using a cheap app like Torque Pro ($5?) and a cheapie $10 OBD Dongle. Good for checking/troubleshooting other stuff too, totally worth $15.
There are other tools that records the goings on of the engine a lot better, but more $ of course. I have an awesome setup (brag) :p
Anyhooo, if anyone has questions on the pump, jumpering or whatever, feel free to ask. And yes it's very important for peak power, if you care about that, and you should because you have a twin turbo V8...
