Trying to order full brake replacement for w212 e350
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
2014 E350 W212 jap import
Trying to order brake replacement kits from either partsouq or rockauto.
Rockauto will probably be easy if I pull whats on there off and actually measure it and take photos.
Partsouq only uses oem part numbers and aftermarket alternatives.
https://partsouq.com/en/catalog/genu...2120592B070132
On partsouq I put in the chassis number and it gives me all the options for that chassis except it doesnt tell me which is the right part for my particular variant just gives the options with less actual picture info and rotor diameter than rockauto does.....
Whats the best way to work out what brakes and pads to order for my particular e350. Im pretty sure its not a sport model. And its rwd.
Im not in the USA so I have to get it right the first time.
Chassis number = WDD2120592B070132 Japanese import....
pierrejoliat (06-10-2020)
You can go here: https://www.startekinfo.com/StarTek/doclist.jsp
Select MB WORKSHOP RESOURCES and a list of PDF files will open, select the entry Vehicle Identification Number Attributes for Model Year 2015
Scroll down about 15 or so and find your year.
Use your VIN# (as opposed to your chassis number) to find the attribute.
If it's not a 4-matic, it's a 'base'
But as said on earlier post, use a place that find parts by VIN# as your best choice. At least if you get OEM numbers, you can find suitable match on other sites with non-BM OE parts
2012 E350 4Matic P2
Please see attached Data Card with your installed options.By the way, nicely appointed MB!!
You do have the AMG Sport Package option (950) which changes the front brake part number,see attachment.
I'm attaching the parts diagrams from the EPC.
Good luck,
Bob
Good luck,
Bob
