Keeping Your Burl Walnut Trim from Fading... a Solution that Works
Aside from the fact that the factory installed trim with inadequate UV protection, I am fairly convinced that the fading is caused by two factors after delivery: 1) Exposure to direct sunlight, 80% the cause, and 2) the remaining 20% due to excessive heat when parked outdoors on a parking lot under the sun.
The first two years, this car lived in sunny Southern Florida (Miami area). I’m certain the previous owner parked at her workplace on an uncovered parking lot. It may also have been parked outside a garage overnight. This explains why the dash trim faded in just 2 years, exposed to direct sunlight that also heated the interior to the usual 120-140° during the day.
She had the windows and rear glass heavily tinted right after purchase, 18% rear glass and 28% front windows. Nothing on the windshield. (I have the receipt.) The Burl Walnut on the rear doors has not faded since new, probably due to the tinting blocking the UV rays. But the forward 3-4 inches by the dash on the front doors was faded, due to the unprotected glass on the windshield. This is how it looked before...
In my possession, the car lives in sunny Texas (DFW area) which is just as hot as southern FL. So the environmental conditions between the two locations are the same.
The difference is that the car parks inside my garage every night. I’m retired, so it seldom sits on an exposed parking lot more than an hour at a time during the day. So, the interior doesn’t get terribly hot.
In addition, when it does sit on a parking lot, the interior is ALWAYS protected from direct sunlight on the dash. In part, I always park facing toward the sun to shade the dash naturally. In addition, I have installed extra items to shade the dash from sunlight:
I installed Limo Tint in the windshield header to block overhead sunlight.
I also installed “The Shade” from www.Dashdesigns.com, and use it whenever parked outside the garage. Opinions vary on the appearance of this pleaded dash cover. But IMO, it covers better than any other option. Its storage on the passenger side A-pillar means it is always handy to use… no fumbling for that folded windscreen shade on the (dirty) back seat floor or greasy seat rails.
Bottom line, the replacement Burl Walnut trim has not faded the last 2+ years. I doubt it will fade in the future, either.
Two years and counting with no fading...
I thought I'd summarize my experience with this for any of you going through the same issues.
The assembly mounts at 2 points on the glass at the RH A-Pillar, and does not block any view out the windshield. Grab the center hand-pull and draw it across to your side, where the nub at the hand-pull clips into a single mount on the driver's side. Installation takes mere minutes, once you are CERTAIN the windshield is perfectly clean where the mounts will be. The kit includes alcohol wipes to assist in cleaning the inside of the windshield edges. But I use these after using Windex and elbow grease first.
The Shade blocks the heat as well or better than any fold-up shade I've ever used. A bare windshield works like a magnifying glass to amplify the heat. But the Shade traps any heat buildup (between itself and windshield) to keep it from spreading throughout the cabin.
In fact, the fully tinted side/rear windows on my car have protected the wood in the car doors since new... not a hint of fading. In contrast, there is no tinting on the windshield, hence the extreme fading on the dash wood, and the first 2-3 inches of wood in the front doors. It's patently clear that the sun through the windshield does the damage. So, I am not convinced that the windshield blocks UVA and UVB rays at all, despite what MB says.
Side windows - well that's another story.
https://www.reuters.com/article/us-h...-idUSKCN0Y32WI
To be clear... I'm not suggesting the wood is perfect from the factory. I've read here -- among the many theories -- that the "sunlight protection" treatment from the wood supplier is inadequate. But the wood will not discolor by itself. Sunlight is the trigger.
I've adopted some simple, easy habits that are now second nature to me. It's worth it to keep the wood looking as nice and luxurious as it does. YMMV
The Shade is a straight-molded assembly, while the A-Pillar is concave, moreso on the E-Class than the C-Class pictured (post #4 above). So the Shade can't rest directly against the A-Pillar. In other words, there is ample space between the two for air bag deployment. See the new photo below. And of course, you decide how close to mount it... closer or farther away.
Further, my understanding is that the side curtain air bag deploys from the bottom/back edge of the the A-Pillar cover (between pillar and door window frame), the same way it deploys from above the side doors below the headliner. As you can see from the picture, that area is well behind the Shade mounted to the windshield. Picture in the E-Class shown below...
Finally, I've removed A-Pillar covers several times to route radar detector wires, etc behind the air bag. The bottom edge of the cover is securely jammed well into the dash itself, while the top of the cover is firmly attached to the A-Pillar frame with a substantial torx screw under the SRS badge. I believe this is designed to keep the cover in place (to avoid injuries from the cover itself) when the air bag deploys from the back edge. In a frontal accident, I assume (hope) the Shade will be trapped between the passenger front air bag and the windshield glass.
You see, I have thought about this a lot before proceeding. For me, the convenience of having a clean shade always found in the same place, by far outweighs the "what-ifs" of an accident. You pays your money and you takes your chances.
Not to mention that many auto brands now have side window curtain airbags, and DashDesigns sells them to all without known problems to date. As mentioned, all of my cars have them, and all are used daily, especially when any one of them is parked outside the garage.
One of my high school buddies drove a hand-me-down '58-60 Buick with factory installed venetian blinds in the rear window. Imagine how that worked in an accident? Of course, we didn't have head rests or seat belts then, either.
Nontheless, I shook the bottle for a good 40 seconds, then applied a layer, let it dry, then wiped off the haze. So far so good?
There are lots of commercial treatments that offer UV protection, including dedicated UV protectants used on outdoor furniture and ceramic decor, like SunGuard UV Protectant. I have not tried this product, yet. Haven't seen a need...
And another product, 303 Aerospace Protectant...
https://www.amazon.com/gp/product/B0...83SOOI2E&psc=1
And another product, 303 Aerospace Protectant... https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
I searched for this thread because I wanted to verify the interior care product I used 2-years ago to treat my wood trim (see post #9 above). It's about time that I re-coat the trim, which I will do once the heat wave subsides a bit.
Since this MB product (privately labelled by Meguiar's) appears to have worked so well, I suspect that Meguiar's own Marine UV Protectant will work as well, if not better. Here is a link to it:
I've also seen some folks who have covered up the faded trim with Vinyl Wrap Film that looks pretty bad-a**. The Black Ash Wood Grain looks pretty awesome in our cars.
