Preventing Relay Attacks (Keyless car theft)
The owner's manual describes a process to deactivate the SmartKey. (Page 91) When the car is locked using the keyfob by pressing the lock button twice in quick succession, the light on the fob will blink twice, then light once more for about a second. The key fob is now deactivated; therefore, touching the door handles, pulling the trunk release, and waving a foot under the rear bumper, even with the key fob in your hand, does not unlock the doors or open the trunk. Pressing any button on the SmartKey fob returns the keyless access system to its normal functioning. Note that if you have two or more SmartKey fobs, all must be deactivated.
This is much easier and more convenient that putting the keys into a Faraday cage for enhanced security. I've been doing this for quite some time, especially when parked in area where the car might be at an enhanced risk for theft. Thought I'd pass the hint along.
https://www.motoringresearch.com/adv...ow-to-prevent/
This topic has been discussed several times.
My second key is deactivated and sits in a drawer. My primary key sits within a Faraday cup when at home. Takes less time to use than deactivating the primary key.
In contrast, dropping my key fob in the faraday cup (based on a metal coffee mug) is no more trouble than hanging the keys on a hook at the back door, or putting the keys in a drawer. The only difference between dropping keys in a drawer and in a faraday cup is the composition of materials (metal vs wood) used by each.
I've parked my car outside restaurants where I can see it from my dinner table... long before I bought my first Mercedes. Just another habit, that's all. A less expensive and aggravating habit than dealing with some insurance claims adjuster who never went beyond 12th grade.
You can test if it truly works by locking the car first, performing the double flash routine, then insert your fingers behind the door handle to see if the car unlocks. If it doesn't then that confirms the key is deactivated.
