Engine Rattling - Help Needed Please!
Long time lurker - was hoping that I could kindly request advice from members of the forum on my current issue.
I have a 2011 E350 4matic Sedan with roughly 114,000km/70,000miles on it and have noticed an engine rattling/knocking/thunking sound the past week.
Today, I have completed an oil change and replaced the upper and lower idler pulleys, belt, and tensioner (when i removed the upper, it was clearly shot as it fell apart in my hand). I torqued the following bolts: upper to ~25nm; lower to ~17nm; and the tensioner to 35nm.
I have only otherwise completed routine maintenance (spark plugs at 100,000km, filters, tranny and brake flushes at 110,000km, and a blower motor replacement twice).
It sounds like it is coming from the upper part of the engine, and not the belts.
Any guidance would be invaluable (fingers crossed this is not an expensive fix!).
Please see the following short video and I hope that you can make out the sound to which I refer (The sound seems most notable on the video at 28s and on):
Thank you all!
When I get some time I will pull the front cover as you have done and see what I can hear.
Kind of seems located at passenger side timing chain cover area but that's a guess of course.
I use a stethoscope but easy enough to take a length of hose and place it at various points on the chain covers, valve covers, water pump, air pump etc. Please be cautious and don't get it wrapped around a spinning belt. Listen at the other end of the hose and it will help you isolate the noise. Bear in mind the injectors will be giving a soft ticking noise at all times.
You've got 2 cams on each head with associated lifters and timing chains, including 4 cam positioners on each head. So there's a number of possible noise sources. My car - same year and engine - has always been noisier on the passenger side right behind the chain covers but not excessively so.
272977 31 520015
So it looks like it is in the range. However, the date is March 11, 2010. So it is out of the date range (though it does say it may be outside the given date ranges anyway).
Engine: 272977 31 932667
VIN: WDDHF8HB3BA491527
Thanks for your input, is this because you believe the defect would lead to short-term failure?
It is an easier decision for me to keep mine because I have more miles (134K) on it than you so if it does fail I have less to lose and in my perverse way of looking at it, it may save me money in the long run because should that happen I will be convinced that Mercedes are no longer designed and built for durability and won't waste anymore money on another one outside of perhaps a vintage model.
So looks like it may be the tensioner/check valve/chain/cam or something on that side.
Does anyone have a walkthrough for the W212 272.977 engine to remove the cover and change these items? Tried searching online but seems more towards the C-class and it seems that different components need to come off and therefore gaskets need to be replaced.
Thanks all
Has anyone found the cause of this issue? I've had the same exact issue for 15 months and haven't had any problems. I noticed the rattle is barely noticeable (if at all) in the summer...During the colder months, it becomes louder. My friend also has the same rattle and has not found anything.
Keep me updated!
Danny
