Sponsored by: CARiD
Steering wheel stuck up, over and over again
Old Oct 21, 2020 | 10:28 PM
Darel's Avatar
Veteran: Air Force
'14 W212 Sport, '52 MG TD, '21 Jeep Gladiator Rubicon
Just dropped off my '14 W212 for the fourth time for the steering wheel being stuck in the full up position.
Once, the WO came back, and I quote, "hit motor with hammer. Working."
They've twice since replaced parts and then the full motor / gear drive assembly. It jammed again, full up, so I just dropped it off again.
My questions are thrice:
1. Anyone else seeing this? The "dog bone" has never been broken.
2. Is there a real fix?
3. My CPO is up in December. I have already spoken to the service manager about the fact that this has already been in so many times and never really fixed, and I am concerned with having to buy a new column or something equally ridiculous in three months. Is there any process for extending a warranty claim for an obviously recurring problem past the warranty period?
Thanks,
Darel
Old Oct 21, 2020 | 10:54 PM
RA72825's Avatar
I never use the easy exit/entry feature. My wheel is set where I like it and never moves. I have seen this problem many times and don’t want to become another statistic. If it keeps happening after your warranty ends you may only get one good will fix and then you will be on your own. I say set it and forget it
Old Oct 21, 2020 | 10:57 PM
Darel's Avatar
Veteran: Air Force
With three drivers in the house, that's not really an option, but I have already disabled the easiness.
Old Oct 22, 2020 | 08:27 AM
RA72825's Avatar
Understand. Multiple drivers do need to adjust the steering to fit. It’s that full up and away that happens with the entry/exit feature that always seems to lock the steering wheel in place. Actually, hitting it, as the tech did is one way to release it. Maybe you’ll have better luck now that you have that feature off. I don’t think there is an easy fix that will last forever. It’s a poor design.
Old Oct 22, 2020 | 08:32 AM
hyperion667's Avatar
2012 CLS63
Will the other cars suffice for the other drivers? Or do they need the Benz?
Old Oct 22, 2020 | 08:59 AM
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
happens to me sometimes too. I just give it a firm pull and it is ok, Not sure what the proper fix is
Old Oct 22, 2020 | 09:05 AM
Darel's Avatar
Veteran: Air Force
Yeah that usually works, however this time it's jammed up good. They are replacing the motor and transmission (just got off the phone with them 10 seconds ago) for the third time. It sounds to me like they don't really have a good fix either.
I'm going to push for some sort of "perpetual coverage" on this one item since my warranty is up in Dec and it's obviously a problem they just fire the parts cannon at. Has anyone ever had any success doing that?
Old Oct 22, 2020 | 10:27 AM
belarus27's Avatar
2010 e550 p2
Its been a few years since ive noticed it on mine
when it started acting up more often , i disabled the feature to save me some nerves lol
Good luck
Old Oct 22, 2020 | 11:33 AM
konigstiger's Avatar
'71 Pinto
FWIW it’s important they observe tightening torques: 1 bolts 4Nm, 2 nuts 20Nm, and 3 bolts 8Nm.
Fliplegend's Avatar
S212 E350 Estate
I love this feature and wish I had it in my bmw. Haven't noticed it fail yet but now I'll be more observant.
Old Oct 22, 2020 | 02:19 PM
dawgfan's Avatar
W212 E350
I had this happen on my 14 E350 3 times while under CPO and then extended warranty: For me, nothing would happen if I tried to move the column up or down, but it could move forward and backwards.
1st time software update under CPO. Fixed it for a few months
2nd time software update under extended warranty. Fixed it for a few months
3rd time they actually replaced the parts under extended warranty.
They did this in July and so far, so good. They claimed no error codes was the rationale for doing software updates.
If I were you, I'd get MBUSA involved. They can open up a ticket on their side and can hopefully help for further issues. Having to replace everything a second time seems like a red flag.
Good luck
Old Oct 22, 2020 | 06:34 PM
up_too_late's Avatar
2015 E350 4Matic Wagon, 2018 GLE350 4Matic
Mine was acting sticky but came loose with a firm tug. After reading others’ experiences with this I also disabled the easy entry feature (no sense wasting cycles on that). I also make a point not to use the steering wheel as a grab handle when entering/exiting the vehicle.
Old Oct 22, 2020 | 07:55 PM
DFWdude's Avatar
2016 E350 Sport
^^^^^^^^^^ yes, this. I use the handle above the door to exit the car, not the wheel. I also avoid using the wheel to reach over to open the glove box, open the passenger side door, or to adjust my seating position. Steering wheel is for steering, nothing else.
Old Oct 23, 2020 | 08:50 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Does the easy entry feature actually make anything easier? All of my 5 Benz cars have had it (as does my Macan) and I always turn it off immediately and never think about it again. Mercedes used to also move the seat, but they stopped that in recent years.
Old Oct 23, 2020 | 09:01 AM
Apparently it makes it easier for the service department to generate revenue. Maybe entry/exit for those with high seat and low steering wheel combination?
Old Oct 23, 2020 | 09:32 AM
DFWdude's Avatar
2016 E350 Sport
Yes, it does. I am on the tall side, and like to sit lower in the seat as a result. This means I need a lower steering wheel position (so I can see through the wheel at the dash). This makes it more difficult getting into and out of the car. The auto tilt wheel is a welcome convenience.
You and I both had C-Classes, which are smaller cars with more confined interiors. I found its automatic movable seat was helpful, too.
Old Oct 23, 2020 | 11:37 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Talking
I think so and use it all the time, My wife and I share her car,{probably why my car has 29k] if it's home I drive it, her seating position is 2 inches higher and 4 inches forward, without the easy entry feature, I would hurt myself.I miss the S class feature of the seats matching the key fob, automatically going to my seat position when I unlocked with my remote.
Old Oct 23, 2020 | 12:09 PM
2012 CLS63
Reading through these comments makes me glad I never 'fell' for that crap lol. It's a wear and tear kind of thing IMM.
Old Oct 23, 2020 | 01:38 PM
LILBENZ230's Avatar
Yes, the key link thing should not have been deleted. The Porsche has it and I swore the E-class did, as well.. but no dice.
Old Oct 23, 2020 | 02:25 PM
Siegmann's Avatar
10-second E550
Push upward on the bottom of the wheel with your knees and continue while lowering it.
Old Oct 23, 2020 | 08:14 PM
Darel's Avatar
Veteran: Air Force
^^^THIS. Hate to say it, but Jeep had this nailed back in the '90s. Had 2 Grand Cherokee Overlands, the 2002 had the seats, mirrors and radio presets keyed to the fob that was being used to unlock the car. Also, you just one-pressed the memory buttons, didn't have to stand there and hold it while the seat moved back enough for you to get in.
Just one of many things Jeep got right and for some reason no one's copied. The ergonomics on those were perfect, and for some reason almost 20 years later cars seem to have gone backwards.
Old Oct 24, 2020 | 12:18 AM
E55Greasemonkey's Avatar
This place is a joke.
Pull the leather steering column boot back (towards the driver), and using the included straw, spray a healthy dose of Wurth HHS2000 or Kent Pene-Grease on the worm gear and metal sliding surfaces of the column. Move up/down several times and apply more. That will fix it.
Old Oct 24, 2020 | 08:45 AM
LILBENZ230's Avatar
Our Porsche links everything from seats/mirrors (including lumbar) to radio and climate control and instrument cluster settings to individual key. I am also surprised this is not more common.
Old Oct 24, 2020 | 08:57 AM
Darel's Avatar
Veteran: Air Force
Never had a Porsche, glad to see someone following suit. It almost seems like common sense.
