Vibrations and Rumbling Sound When Turns
This morning weather turn a bit colder and after warmed up the car for about 3 minutes.
I then reverse out of the parking spot and there is Vibration that I could feel in the whole car, plus the rumbling sounds, not that loud but could hear it.
I drove to my work about 3 miles from where I live and there's huge empty parking lots so I decided to test the car.
As soon as the wheel turns there's Vibrtion and the Rumbling Sounds either Forward or in Reverse.
I used to live in Seattle, Washington during Winter before and never had problems like this time.
I need help to identify the problems or at least some ideas what may cause these problems.
Any help would be much appreciated. Merry Xmas.
Mines sleeps on a garage so my fluids stay the same, but I am in Florida.
Harsher weather will necessitate more fluid changes.
That was my first thought too, when he mentioned backing up. However, I wonder it’s its only when the wheels are turning, turned and/or vehicle is in motion.
Turning the wheel puts load on the engine (via ps pump) and at idle it’s more perceptible. It can amplify motor mount vibration and worn accessory belt system (idler, belt and/tensioner).
By the OP's first post vibrations appear only when car turns at slow speed in parking lots etc. This is about speed difference between front and rear axles so the #1 thing is to look at the center differential. It could be the transfer case too, which gets more load with speed difference between axles.
If it was motor mounts the problem would show up also going straight.
This same issue is discussed in thread "What are my odds".
Also at one of the stop after I release the break pedal I feel the rolling kick, so that possibly the xfercase.
