Sponsored by: CARiD
Starting issue
Old Dec 27, 2020 | 03:04 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
Starting issue
Im having trouble with starting my 2014 E550. Started with key goes in, but I don’t hear the ‘grab’. Able to turn it all the way but nothing. Lights and everything work. Service Menu says battery at 11.7V but I replaced with a new one anyway. After replacing battery, same issue. I decided to try again by stepping on the brake while turning the ignition, then it...magically got the car started. Drove it around and starts again, no problem. However I still don’t get the key ‘grab’. Any idea what could be the problem? I’m driving home tomorrow and will bring to a mechanic, but wondering if this will leave me stranded - or if I should be checking something?
Old Dec 27, 2020 | 04:07 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
It sounds like EIS/EZS - ignition switch - issues. Do you have a scanner that can read codes?
Old Dec 27, 2020 | 04:20 PM
DFWdude's Avatar
2016 E350 Sport
Ok what am I missing? On my 2016 (same facelift model as yours), it will not start unless I STEP ON THE BRAKE, first. Says so in the manual. No magic involved.
Old Dec 27, 2020 | 04:46 PM
Just to note, I do not have keyless go. Will see if a local shop can read codes tomorrow and will report back if I have success.
Old Dec 27, 2020 | 06:03 PM
LILBENZ230's Avatar
No need to press the brake to start it with the key. I have KeylessGo but I use the key to start the ignition (preference).
Old Dec 27, 2020 | 06:14 PM
DFWdude's Avatar
2016 E350 Sport
Sorry. MB is so concerned with accidental roll-backs, I thought you needed to step on the brake for either method. Carry on...
Old Jan 14, 2021 | 07:42 AM
Following up, it was just the key. Found the spare and it worked fine. But to note, I read the manual and it says even a bad/wrong key will turn in the ignition...didn’t know that!
Old Feb 1, 2021 | 06:04 PM
Problem came back, it happens when it’s freezing temperatures, when car is cold sitting outside. When car is warm or temperatures are over freezing, no problem. Finally got a code U0101, fault with communication with transmission control module. Is there a sticky relay I should be checking?
