E class w212 2012 stuck in park ..column shifter
oh dear its so easy to upset people here.
im sorry I didn't reply directly to your comment about testing the circuit..
I did test the wheel sensor but I am not able to get leads on the two pin plug coming from the chassis ..its buried at an angle in the side wall. I will try again when I have some dry weather..I work on a public road not a drive way so its more difficult to get properly under the car....wiggling the sensor wire hasn't changed anything since it briefly worked all those days ago.
I might add that ive spent a grand total of £18 on a Bosch wheel sensor and used a new battery that was fitted to my cl500 ..not really a cannon of parts but hey ho..my dads 90 today and I don't think he's changed anything other than windscreen wipers in all those years of driving.
As mentioned its a clue regarding moving the sensor wiring or getting the connector wet, then seeing issues. Checking the harness further upstream can also be of value.
A scanner will be of benefit to see what's not communicating on the network, especially for an intermittent problem. But also as mentioned a scantool that can access the vehicle systems and modules is of much greater value than a generic obd version.
Received 1,008 Likes
'11 E350, '11 E550, '98 M3, '95 E320
Looks like the two main permanent faults are related to the steering column module and Direct Select Control Unit. The latter, I'm not sure if its referring to the ISM or the direct select lever on the column. Is the direct select lever a separate module or part of the steering column module?
This may be useful:
This may be useful:
pierrejoliat (03-12-2021)
This may be useful:
This may be useful:
I will absorb what I can fro the info you sent me and get back here when ive diagnosed further ...
I'd focus on the steering column module (SCM)... if your scanner supports live data (actual values), then you can read out the "status" of the direct select lever, cruise control and steering angle. The SCM supports: steering angle, combination switch, steering wheel buttons, horn, steering column adjustment, steering wheel heater, cruise control/distronic, direct select lever and steering wheel shifter paddles.
Does the column adjustment, horn and steering wheel buttons work?
I would start by:
Other things to check would be powers, grounds and CAN to the module. I would suspect, ALL the functions would be dead if those where the case... but its always good to verify, especaiily when its an intermittent issue.
I would start by:
- communicate with the SCM (N80)
- clear codes in the SCM
- reconnect
- actuate the faulty switches and verify the module recognizes these inputs
- then I'd repeat for the remaining switches.... if they "work" then this should validate the module recognizes them
#32
To add, I think W212s having center console shifters have a separate electronic selector module and/or direct select interface. Those with column shifters, I believe its integrated into the steering column module based on what I see in Xentry.
#33
I did some live checks and there is no communication with gear selector...I was able to use the computer to change the gears and drive it like that .....
Ordered in a replacement steering squib.....with the limiter,gear selector and washer wiper indicator stalks and after fitting that most of the faults disappeared .
Seems to work well
I can not find a way to reset the airbag on the steering wheel
when the car comes to a stop at a roundabout or stop sign it’s eco system switches engine off and restarts when I lift off the brake but then immediately switches the car off and I have to manually restart it .
Anyone had an issue with eco start restarting after stop only to **** down again almost immediately
Seems to work well
#34
Seems to work well
Seems to work well
Now as far as your new issue, did you perform the start-up for the steering column module? I pretty sure there's a start-up and it might include steering angle calibration. Beyond that, again... I start by making sure both main and auxiliary batteries are FULLY charged (use a external charger on both). Then disconnect he main battery for 10 min. Reconnect the battery and read for codes. Write them down and clear them all.
Go out and drive, replicate issue, come back and scan for codes.
pierrejoliat (03-25-2021)
#35
s the steering squib solved all the issues and by using a different mercedes vehicle model in my diagnostics,Delphi 150......I was able to access the reset for steering wheel air bag ...so the wiggling of the wheel sensor was a red hearing that managed to reel me in for some time before the line snapped...
thanks everyone who posted reply and spent the time and patience for me..
pierrejoliat (04-29-2021)
