S212 rear center seat belt won't pull out
I would think it is a single bolt holding the end of the belt that you access by removing the rear seat. No need to tear into the seatback.
This is not a lube issue either. If the belt is tightly wound it just means it wound just a bit too far and won’t release from the brake or lock built in it.
This same exact thing happened to my 2017 Durango and the only way was to unbolt the end of the belt to get the belt winder to release.
Does the belt pull out a little and lock? If so, I've had success jiggling the seat back and belt to "release" it.
I guess you just have to take apart the seat? Undoing the bottom anchor won't do anything if the belt won't feed past the plastic button, I'd think.
For some reason, my WIS copy isn't working right, either. Do I take the back of the seat off? Looks like two cleats at the top of the seat held on by twin torx screws, but that might just be for the cargo cover when it attaches to seat.
Maybe try folding it again, and giving it a good slam when locking it upright.
I’ll take a look in WIS later.
Thanks for the WIS pages!
A new center seatbelt assembly is ~$200.
I thought that I had the same issue a while back (on sedan) but then realized that the center seatbelt simply has a very sensitive tilt sensor that locks the belt in anything but the normal seated position. Even a few degrees off and it locks, I assume this is a safety feature for rollovers. I actually started to take the seatback apart before I realized that it worked, but only at just the right angle. Not sure if this is your issue but I figured it'd be worth sharing.
