Engine surging 100-300 rpms
Car was neglected, did the problem exists before you did maintenance? Any of that maintenance could have caused a vacuum leak?
on every EFI car I've had before this one, any time I've removed the throttle body, I've had to use a new gasket. this includes W124's with m103, m104 engines, volvos with various b230f(t) engines, VWs with whatever 4-banger CIS injected 1.8L my 84 and 89 had, etc etc.
If the separator cover was that bad, the internal assembly probably needs replacement. Issue is that if it's not working properly, it won't keep the oil on and only allow oil vapors to be reburned (routed into TB and intake). Oil getting into the TB and intake can turn into coked deposits - in the case of the V6 it can cause the intake internal flaps to eventually jam and break the plastic actuator rod(s) at the front of the intake.
A major factor that I see is that you have a car with unknown and neglected maintenance. A shudder can be tricky to diagnose as it can be a function of engine or transmission issue. Again, a decent scantool can at least help point to a direction to look at. Strongly suggest that if you get a scanner, get one that can look at all of the vehicle modules, not just a basic OBD2 version. They are a bit more, but much more useful over the long run. Or take it to someone that can do this and is familiar with these cars - money spent here for a thorough vehicle inspection and diagnosis can save the time and expense of buying parts hoping they will fix a problem. Plus give you a heads-up on pending troubles. Best is to look for a local indy shop that has a good reputation and knows the german cars.
Also worth noting, internet people preach day and night to treat a MAF sensor like it's your great great grandmother's fine china. Just another fairy tale cooked up by the uninformed. The sensitive resistor element is what is necessary to avoid direct contact with, and it is largely protected within the MAF housing. So by all means, pull it, inspect it, clean it, test it, handle it. Just don't throw it against a wall or drop it in the mud.
but anyways, the M276 engine in most of our 212 V6s and I presume the M278 V8 equivalent, they don't have any MAF, just a pressure sensor, which is an alternate way of doing it.... pressure sensor based injection systems typically need a throttle body position sensor, but if its drive-by-wire like these cars, thats baked in. I've also not heard of many of those MAP sensors failing on the older euro cars I've been around, but they are certainly cheap enough. I did have to replace a MAP on my son's old Tiico Audi-I4-converted Vanagon Westfalia, but that was because I upgraded the original Tiico ECU and the original MAP didn't have an embedded temp sensor that the new ECU wanted. of course, this meant replacing the harness connector for the MAP and running an extra wire to the ECU.... when I was done, that Vanagon ran like it had never run before, then a couple months later, his dippy GF ran the oil dry and seized the motor, ARRRRGH. yeah, he knew the oil pressure light wasn't working, I told him to fix it, but did he listen to Dad? naaaaaah.
for parts lookup I'm pretty competent with the Parts Information system that I'm paying $75/year for access to (hey, when you own 4 Mercedes, why not?), but again, the stuff on that WIS/EPC is awful, I can't find anything.
say, does your WIS virtualbox pirate edition WIS crash a lot? mine locks up if I look at it sideways, and I have used the same VirtualBox to run all sorts of other VMs without a single hiccup for years. Now, I imported their vbox/vdi files into my existing VirtualBox 6.1.12 r139181 install rather than running whatever funky oldder vbox the disks had on them, and I did update the VirtualBox Extensions of their Win7 Pirate Edition VM to be compatible, so screen sizing works.
hah! the things we do.
