Sponsored by: CARiD
W212 DIY'er Scan Tool Must Have... info on generic to factory tools
Old Mar 23, 2021 | 02:13 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
For all those asking about scanners... this came across my Youtube feed:
He covers from generic to factory scan tools and makes a lot of good points. I really like his philosophy on not chasing codes... write them down first, then clear them and only go after actual faults. Every time I scan with DAS, Xentry or Launch there are codes... almost a given, doesn't mean there's an actual issue.
At the minimum, any W212 owner should be looking at something like an iCarsoft MBII or better.
Old Mar 23, 2021 | 08:55 PM
Fred2's Avatar
Sprinter, agate grey sports car, e350 Wagon, S
Any thoughts on the Xentry clone type systems.
https://www.ebay.com/itm/Mercedes-Be...IAAOSwNANegHU2
Old Mar 23, 2021 | 09:23 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I think those Xentry clones can be had for about $1,000 less than your link indicates. There's a member here that can get you set up but I'm not sure his name. Someone will pipe up, I'm sure.
Edit: Shardul, maybe?
Old Mar 23, 2021 | 10:59 PM
BenzNinja (on forum) for C4 Xentry setup is ~ $1000 He's opinionated on the subject and sells a service, but has many happy customers. You can also source C4 setups off eBay, AliExpress among others for $500-800... but you won't get any support.
Old Mar 24, 2021 | 11:13 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
There is scanner section on Sprinter forum, who gives very good reviews what is available on the market.
When Xentry is something needed for coding and adaptation, the best deal for end users is Autel dongle for $49.
I had Sprinter failure couple months ago and the scanner made very nice troubleshooting page, with all crucial parameters displayed on single page and required parameters highlighted.
I
Old Mar 24, 2021 | 11:23 AM
Share the link @kajtek1 to the scanner section...
Old Mar 24, 2021 | 11:26 AM
kajtek1's Avatar
https://sprinter-source.com/forums/i...hp?forums/205/
