Sponsored by: CARiD
Code: 2568-09 Premair Sensor
Old Mar 23, 2021 | 03:22 PM
Papaspence's Avatar
E350 4Matic, E400 Coupe, 280 SLK, 500SL
Exclamation Code: 2568-09 Premair Sensor
Hello All,
I'm dealing with an issue with my 2013 E350 4Matic. My mechanic is reading it as a 2568-09 Premair sensor malfunction and it makes the fan run constantly. I was told that it could be the Coolant Temperature Sensor (P/N: MB-221905560080) that is mounted on the radiator. I had it replaced with an OEM rebuilt and the light stayed off for 4-5 days. Now it's back on with the same code and fan running. Anybody got other ideas? I could really use some advice here. Thanks!!
Papaspence
Old Mar 23, 2021 | 03:44 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
What did you have replaced with an OEM rebuilt? The premair sensor, coolant temp sensor, radiator or fan? Wouldn't be the first time a rebuilt or even new part is bad... Of coarse thats assuming the sensor was the issue all along and not a wiring, power/ground or corrosion problem.
Seems this premair sensor is only for PZEV vehicles.
Old Mar 24, 2021 | 04:57 PM
Arrie's Avatar
Another thing that makes the fan run (and fast) is high A/C pressure reading. Does the fan run (fast) if you turn A/C OFF?
