Sponsored by: CARiD
Windscreen nozzles
Old Apr 25, 2021 | 12:11 AM
  #51
Umairkhalid's Avatar
Suzuki cultus, Hond city 2011, Honda city 2003, hopefully and E250 soon
Originally Posted by Left Coast Geek
the calcium and manganese are mostly in the form of carbonates, which are almost insoluable.
the H-Cl releases the H, and the calcium carbonate becomes Calcium chloride, magnesium carbonate becomes magnesium chloride, both of which are soluable, and the carbonate part becomes carbon dioxide which bubbles away along with the hydrogen. some of the H and O becomes H2O (water). something similar happens with the sulfates.
sorry read the first message wrong, I thought you meant chlorine gas but its hydrogen.
Old Apr 25, 2021 | 12:37 AM
  #52
S-Prihadi's Avatar
Originally Posted by Umairkhalid
wait how does that produce chlorine, do we get salts, calcium chloride and Magnesium chloride with hydrogen gas.
I think you are confused with salt water chlorine generator for pool.
The so called "no chlorine" pool but water has to have approx 4,000 PPM ( part per million ) or 0.4% table salt in it and then the chlorine generator which makes chlorine by process of electrolysis.
Chlorine, liquid = sodium hypochlorite
Tabel Salt = s
odium chloride
https://www.watersafetymagazine.com/...e%20stabilized.
Our eyes is most comfy at pH 7.2
Adding chlorine to sanitized pool also created high pH water when the chlorine is not TriChlor and Dichlor, but the common liquid chlorine or granular chlorine/calcium hypochlorite.
So to reduce pH, HCL is used or muricatic acid or sodium bisulfate/dry acid.
HCL is also the lead acid battery "1st time" water/electrolyte.
Old Apr 25, 2021 | 12:52 AM
  #53
Tabel Salt = s
odium chloride
yes sorry I was in a hurry and read the sentence wrong, otherwise I got the gist. Cheers
Old Apr 25, 2021 | 12:58 AM
  #54
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
um, lead acid batteries use SULPHURIC acid, H2SO4. HCl is too volatile.
Old Apr 25, 2021 | 11:23 PM
  #55
Update: so guys I put everything back and thankfully at least one of the 2 blocked nozzles did actually opened up and is spraying. So out of 2/3 are working now, and I'm defo not gonna be working on the third one for a while. However, while putting everything back the plastic panel in which the nozzles fix, is not sitting seamlessly into a plastic holder (I don't know what to call it) that's I guess glued beneath the windscreen. I manage to fix in it in completely from the ends however through out the middle the panel is raised and doesn't fix in. Applying pressure doesn't help as much since the part that is supposed to go into that long holder doesn't go in and instead pushes the holder down further which would I guess slightly deform in and pulls it from underneath the windscreen. Is this thread where I should be asking this or create a new one?
Old Apr 26, 2021 | 10:32 AM
  #56
konigstiger's Avatar
'71 Pinto
See attachments that may help.
File Type: pdf
File Type: pdf
Old Apr 26, 2021 | 10:48 AM
  #57
this was pretty generic and does not address my problem since I have been able to done everything these 2 manuals say, what I mean is fixing the plastic panel (in which the nozzles/brackets) are fitted, it isn't sitting properly back into place, doesn't slide in correctly in the holder that is under the windscreen. Additionally where did you get these manuals?
Old Apr 26, 2021 | 01:43 PM
  #58
those are all sections from the WIS, Workship Information System.
Old Apr 26, 2021 | 07:09 PM
  #59
I get that those aren't public, and not free, is it possible if you could share the whole manual?
Old Apr 26, 2021 | 07:11 PM
  #60
its thousands and thousands of mostly 1-2 page PDFs
without the WIS app to find them, you'd never find anything
oh, and on the WIS DVDs, they aren't PDF files, there are multiple 2 gigabyte sized encoded container files, WIS can *print* a PDF from a specific page after you've found it. these container files are named like rfile00000.000, rfile 00000.001, rfile00001.000 etc. and they are not in zip, 7z, rar, tar, gzip, or any other format that Win7Zip recognizes, so they are probably encrypted.
Old Apr 26, 2021 | 07:14 PM
  #61
so its an app? Could you share the name please.
Old Apr 26, 2021 | 07:22 PM
  #62
WIS - Workshop Information System
you can buy bootleg copies on ebay etc, most of these are setup to run as a VM under VirtualBox, and have the normally copy protected program 'cracked' under a Win7 32 bit OS that runs in said Virtual Machine. The legit version is $$$$$/year from Mercedes.
Old Apr 26, 2021 | 11:42 PM
  #63
thank you!
Old May 13, 2021 | 03:22 PM
  #64
jcakers's Avatar
'85 380SL, '10 E350, '16 GL450
Calcium carbonate or magnesium carbonate react with HCl to product calcium chloride (or magnesium chloride), carbon dioxide and water. No hydrogen gas is produced.
CaCO3 + 2 HCl ---> CaCl2 + CO2 + H2O
Old May 22, 2021 | 11:37 PM
  #65
UPDATE
UPDATE: so randomly out of the blue guys I was driving on a highway yesterday (it was slightly raining anyway) I was curious to see whether the nozzles work or blocked again and miraculously all the 3 were squirting water, even the remaining blocked one, filled me with joy. Someone it opened suddenly, somehow, will be adding distilled water and some light shampoo in the tank.
Old May 23, 2021 | 12:45 AM
  #66
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
What kind of Shampoo? I like Head and shoulders.
Old May 23, 2021 | 12:48 AM
  #67
I'm sorry but is that sarcasm ☠
Old May 23, 2021 | 09:18 AM
  #68
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Talking
After all that work, I'm glad it's working, I'm even happier the shampoo remark was facetious! Glad it all worked out for you.
Old May 23, 2021 | 09:21 AM
  #69
it wasn't facetious, so shampoo is a no no, will try and find some workable washer fluid here then.
Cheers.
