Sponsored by: CARiD
Fuel door won’t close
Old May 17, 2021 | 11:43 PM
Kwh's Avatar
Kwh
2011 Mercedes Benz E350 Sedan
Hey guys, I ran into an issue with the fuel door on my 2011 E350 sedan. The small magnet on the inside right hand side of the fuel door (allows for press action opening and closing of fuel door) came loose as I was opening the fuel door to get gas. Just my luck, the tiny magnet piece happened to fall into a tiny pinky finger-sized hole next to where the gas nozzle would go, and it appears to go down inside the car. Has this happened to anyone before? Is there any chance of getting the magnet out of there? If not, what is the name of the part for the magnet so I can replace it? I’ve been searching everywhere and can’t find any mention of a similar situation or the name of the fuel door magnet. Any help would be greatly appreciated!
Old May 18, 2021 | 01:04 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Did it drop into the filler area drain?
Old May 18, 2021 | 05:50 AM
BenzV12's Avatar
W212 FL
I had fuel door problems but it was about lanyard or cord related .I have not heard of what happened to your car as before
Old May 18, 2021 | 10:42 AM
konigstiger's Avatar
'71 Pinto
Magnet is incorporated into recess hinge MB does not offer it separately shop 2126300067 or 2126300000 used, see attachment to replace or manipulate DIY repair.
File Type: pdf
Old Mar 13, 2022 | 01:38 PM
shekmark's Avatar
2019 E53 Cabrio, Lunar Blue. 2020 GLC 300
My E53 fuel door has trouble staying closed after a gas stop. Can anyone offer advice on why and how to correct it? The gas attendants work at it for a while and it finally stays shut.
Old Mar 13, 2022 | 02:47 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Sometimes the gas cap tether gets tangled up and the door won't close well, being in Jersey with full service this could be the issue, the attendants should of figured this out by now though as there are lots of Benz's and no-one pumps their own gas there.
My son lives in Mendham, so this has happened to me a few times there when we visit.
Old Mar 13, 2022 | 03:06 PM
shekmark's Avatar
thanks I will check that out!
Old Mar 13, 2022 | 03:31 PM
Never heard this one before but s*** happens, maybe you could run an 18 gauge plastic coated wire down the overflow tube to see if its still in the tube? Or a low psi air burst to force it out the bottom? I don't know, but If you could figure out the specific sizing, maybe a hobby shop or craft store would have a suitable replacement?
Old Mar 13, 2022 | 03:34 PM
Just remembered, I think I read somewhere that the tether needed to point at the seven o'clock position were it was attached to the fuel door.
