Sponsored by: CARiD
Recommendations for adding carplay to 2014 E350
Old Jun 22, 2021 | 11:41 PM
billtang's Avatar
e350
Any recommendations for adding carplay to 2014E350? Currently considering two systems, the first replaces the existing display with a Android based larger touch screen display with external mic and gps antenna. The second is just adding carplay through AUX without replacing the existing system. I wonder whether the Android based touch screen display is an overkill if I just want to use carplay with the apps on my iphone. Thanks.
Road Top Android 10 Car Stereo 10.25" Car Touch Screen for Mercedes Benz E Class S212 W212 E200,E250,E300,E350,E400,E500,E550,E63 AMG 2009-2014 Year,Built in Wireless Carplay Split Screen 4GB RAM
https://www.amazon.com/dp/B07P9GYM7Q/ref=cm_sw_r_cp_api_glt_fabc_M9PQ7PRN0HRRSPH9NTE6?_encoding=UTF8&psc=1 https://www.amazon.com/dp/B07P9GYM7Q/ref=cm_sw_r_cp_api_glt_fabc_M9PQ7PRN0HRRSPH9NTE6?_encoding=UTF8&psc=1
Road Top Wireless Carplay Retrofit Kit Decoder for Mercedes Benz ntg4.5 ntg4.7 C/E/CLA/GLA/GLK/CLS/ML/GL/GLK/SLK Class 2012-2015 Year, Support Android Auto, Mirrorlink,
https://www.amazon.com/dp/B084LZL126/ref=cm_sw_r_cp_api_glt_fabc_M7X0R019WXD5JVWFMZE5?_encoding=UTF8&psc=1 https://www.amazon.com/dp/B084LZL126/ref=cm_sw_r_cp_api_glt_fabc_M7X0R019WXD5JVWFMZE5?_encoding=UTF8&psc=1
Old Jun 23, 2021 | 12:47 AM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
having used touchscreens while driving, I would *FAR* farther have the knob integration and NO touch screen when I'm behind the wheel. if the road is at all bumpy, touch screens are unusable.
Old Jun 23, 2021 | 11:09 AM
Darel's Avatar
Veteran: Air Force
'14 W212 Sport, '52 MG TD, '21 Jeep Gladiator Rubicon
Very interested if anyone's installed either of these. I've seen lots of other options that are way more expensive and invasive to install.
Old Jun 23, 2021 | 11:56 AM
cadetdrivr's Avatar
2014 GL350
FYI, there's a huge thread that I started with instructions on installing the Road Top retrofit kit (uses OEM screen):
https://mbworld.org/forums/e-class-w...4-5-4-7-a.html
Old Jun 23, 2021 | 12:50 PM
Darel's Avatar
Veteran: Air Force
Wait this is that same unit?
Oh wait, I now see that thread (which I haven't checked in in for a while) has been updated to show this piece instead. Thank you!
Old Jun 23, 2021 | 06:08 PM
billtang's Avatar
e350
The size of the original 7 inch screen is almost the same as the 6.7 inch screen of iphone 11/12 pro max on a holder. I wonder if it is worth the effort of tearing the panels apart to integrate the road top unit while keeping the original 7 inch screen.
The android based system with the 10.25 screen looks nicer but I wonder if it is able to integrate existing the steering wheel buttons and the knob seamlessly. I read that the existing mic won't work and an external mic is to be installed. In that case, some functionality of the existing system is gone.
Old Jun 23, 2021 | 08:50 PM
strife's Avatar
560SL, 380SL, E350
FWIW, I installed one of these with a 7" original screen and I find the size to be adequate (on Carplay; Apple did a pretty good job of working with the pixels and size that they had to work with). I considered the alternatives but I still can't stand the "tacked on" look of detached screens EVEN IF they are OEM.
Old Jun 25, 2021 | 11:02 AM
samkimg's Avatar
2023 XC60 PHEV, 2023 XC40 BEV
I’m trying this unit (
Amazon Amazon
) because i didn’t want to tear my dash apart. I have it installed on a cup holder stand for now and haven’t done wiring or driven too far for location. I am hopeful.
Old Jun 25, 2021 | 12:21 PM
fallen's Avatar
2014 E550, 2015 E63S, 2017 G63 - RIP
Interesting solution... Trying to figure out how this is better than a mounted iPhone.
IMHO it adds complexity of the extra bluetooth connection and additional (not to mention the looks) equipment to achieve the same result as dash mounted iPhone.
Am I missing something?
