Loss of AC on W212 Bluetec
It's ok though, just bleed off some refrigerant and hope for the best. Don't waste time trying to diagnose the system or understand how it works.
When evaluating pressures wrt charge, you need to account for outdoor/indoor temp and humidity. Where's by filling by weight, negates all those variables.
The most down to earth but full blast explanation Toyota made ages ago for the workshop tech and the only one I seen using see thru refrigerant block on evap and condensor to see refrigerant liquid/vapor state.
PT Chart.
Too bad W212 evap temperature sensor accessible using icarsoft MB v2.0 scanner, is air blown based reading and not physical temperature of the evap coldest pipe. If one can place a thermocouple on the evap coldest pipe section, this chart would be good to use to assist for better accuracy .
The condensor side is easier if anyone wants to attach a thermocouple.
Happy troubleshooting......
