Sponsored by: CARiD
Engine Almost Stalls on Start. Any Ideas?
Old Jul 2, 2021 | 07:39 PM
DeTh's Avatar
W212 E350
Unhappy Engine Almost Stalls on Start. Any Ideas?
2013 W212 E350, ~46k miles
Haven't had any problems aside from 'alternative battery malfunction' for a couple days (around a week or two ago), but it disappeared before I got around to ordering a new battery.The problem is the bog when starting the engine. Watch the RPM's drop to almost 300. Felt like the car was going to stall.
Car normally cold starts to around 1k RPM until the Camshaft Positioning Test is over (correct me if this is wrong), then drops to about 600. If you listen, you can hear it drop lowwwwww and then go back up to 1k.
File Type: mov
Old Jul 3, 2021 | 02:03 AM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
I would check fuel pressure. Perhaps turn key on, wait a few seconds, the turn to start. Prime the pump and fuel system, then start. See if any difference. May not be, but maybe.
Old Jul 3, 2021 | 08:18 AM
Jocahox's Avatar
2007 230 sport
Change crankshaft position sensor
I had same issue and changed crankshaft position sensor which is a ***** cuz of placement back of lower left of engine but that help it
