MERCEDES E350 M276 2013 ticking noise
Subscribe
Aug 6, 2021 | 04:29 PM
Hi guys , just joined the forum ,wondering if anyone has the same noise from the engine bay during the cold start, I own 2013 E350 m276 75K miles ,ticking always starts 30-40 seconds after the cold start and increases if i hit the gas pedal ,it stops after reaching temperature around 60 °C , usually takes a minute or so , drives fantastic though no CE light. I took the car to local MB dealership and left it overnight , they were suspecting the chain tensioners at first but after checking on cold in the morning they said it's normal and the noise is probably from HPFP , What's your opinion guys could it still be chain related problem ? .
sounds exactly the same
https://drive.google.com/file/d/1PyC...jmcxfsEzI/view
appreciate your help and sorry for my English
Reply 0
Aug 6, 2021 | 06:08 PM
See attachments (capture supports bulletin). If you do not know your engine # provide VIN.
Reply 0
Aug 7, 2021 | 10:21 AM
Thank you ,
I checked the attached audio track . I never have that rattle upon start up , so does that exclude the timing chain related problem ?
https://drive.google.com/file/d/1PyC...jmcxfsEzI/view noise begins at 0:45 , 40 secs after engine start .Like loud diesel engine sound , goes away in a minute .
Reply 0
Aug 7, 2021 | 12:27 PM
How long have you owned the vehicle?
Reply 0
Aug 7, 2021 | 12:53 PM
Only a month, I'm a second owner
Reply 0
Aug 8, 2021 | 08:21 PM
Direct injection engines, such as the M276 that you own, sound a bit like diesels when running. The reason is the high fuel injection pressures and the high pressure pumps required.
Note the sound for a while and see if it changes.
Reply 0
Subscribe
Currently Active Users (1)
