Auto Headlights issue
I started the car and the headlights came on with the high-beams, so I switched it to "A" and back to "0" to see if they would go off, they did not. The sun was coming up so it wasn't really dark at all.
Anyways with all that, I will hook up my Autel scanner later today to see if there are any codes. What's confusing to me is that when I look in the owner's manual the switch they show is different than the one I have, the switch in the book does not have the "0" position with I believe is a zero and represents off?
It doesn't turn anything off though. In my experience "A" means flicker between DRL and low-beams at random. "0" means the DRL are on and the low-beams come on at night.
Now your lights are being switched ON at night while the car should be in low power mode.
I re-read this whole thread for background consideration... Something is causing your F-SAM to act up while it should be asleep.
We are going to run out of simple tricks very shortly. I would try to exercise your light selector module back and forth as I am sure you did that a lot already! It is built around insulated carbon tracks and a set of wipers engineers thought should work dry without any anti-oxidation grease. It is powered 24x7 to message the F-SAM relays, so it has great habilities to cause your light show.
At the end of the day I think your F-SAM circuits are going to need consideration & TLC.
Consider floating your main battery so it does not get drained to death by restless modules.
I ran the scanner and I noticed two :
State: Historic
A Bus Keepawake Unit Was Detected
State: Historic
An Implausible Signal From Switch "Exterior Illumination" Was Received.
I saved the output of the scan so later this evening I am going to hook the scanner up to my laptop and see if I can share that.
-Stephen
BENZ_EN_TEST_00004>VIN Identify>Quick Test>Driver-side SAM - Front Signal Acquisition And Actuation module(N10-1)>View Data:
Total Frames: 8 , Supported Items: 7
Frame 1/8:
Voltage At Circuit 30 ----- 14V
Voltage At Circuit 30G ----- 13.8V
N10/1kK(Circuit 15R Relay) ----- ON
N10/1kJ(Circuit 15 Relay) ----- ON
Status Of Circuit 15X ----- ON
Status Of Circuit 58d ----- OFF
Power Consumption Of Component 'Circuit 58d' ----- 0mA
So that seems fairly useless? I am going to mess around with the scanner and see what else I can get.
I believe with the car locked and off, the light switch still has power, especially with right side parking lights on, could this be why the bus keep awake/ F-Sam was powered up? And spit out a code?
Frame 1/8:
circuit 30 - unfused always on battery power
circuit 15 - switched ignition power (on with ignition or start)
circuit 58d - instrument lighting dimmable circuit
I do not see 30G or 15R/15X as being part of the standard, although I think I've seen them used before (15R is powered on in ignition OR aux, 15X is powered in ignition ON but NOT when the starter is engaged). AH, apparently 30G goes off some hours after the car is shut down and locked.
(Only plug your Sw back in if/when you do need lights ON)
Disconnecting the SW will give you a confidence level towards "switch likely good" -Or "switch likely acting up".
I am unfamiliar with your exact switch style that incorporates the Fog position and a "0" position.
I know it does not switch any power by itself.
I forgot what style of connection this switch uses to message relay controller @F-SAM (busy CAN-B -Or dedicated wiring)
I'll leave it out for a few days and see if the light stays off. If so I will order the part. As far as I can tell the part number for the switch assembly is: 212-905-73-02
Thanks again, probably should have just replaced the switch as pointed out in the earlier posts.
-Stephen
With key in ignition even without turning it to position 1 , that light wont be activated.
That is how it works in my car.
ZERO is daylight by default and can not be turned OFF, unless in instrument cluster menu I turn it off.
Sometimes ON with key insert and ignition posistion 1 or 2 I forgot and guaranteed ON with engine running.
I by accident, using Xentry messed around with what they call light DEMO MODE.
By the time I unplug the laptop, the parking light BOTH sides stay ON forever and cant be turned off...Car Show Mode I guess
So I went back to kill that mode with Xentry Pass Thru.
Check if your iCarsoft V3 has that feature and who knows it was accidentally activated somehow, albeit you are getting only the right side parking light, which I assumed FRONT & REAR.
So I have a question regarding the IWC clock for C63 2017.
the clock just stopped moving @5 and when ever I try to change the time in the car it just stays the same.
I opened the center console checker the wire it was connected properly.
tried removing and reattaching it again but still no use.
