E550 in to safe mode.
my long term fuel trims at idle are bank 1 between 71% and bank 2 14% and when shut off drop between bank 1 46% and bank 2 9%.
Could the sensor cause this? High pressure fuel pump? Possible vacuum leak? Anywhere else to look?
The right tool will tell you what it is right away.
Take it to a reputable Indi if you don't know what it is. You can also run a fuel injector cleaner, and pray for the best.
Look for my post about this to identify them.
fuel trims are wonky on bad o2 side (bank 1).
This, of course, can be a pump issue but it can also be the pressure sensor issue, i.e. sensor reading wrong.
In your post you mention low pressure and this pressure probably is in the high pressure side so as the car went to what you call “Safe” mode (I think it is the Limp Mode) I would concentrate my attention to the high pressure side sensor and pumps. Sensor I s located I the fuel rail on the right side of the engine. There are two high pressure pumps by the fire wall.
Easiest is to check the pressure sensor first.
Update:
Below is the name of the thread that discuss fuel pressures and sensors in depth. It is in 212 forum.
how-diagnose-p0087-fuel-rail-pressure-low-fuel-pressure-sensor
