Eco Mode Has Been Resurrected
The ability to RESTART the engine comes on top of the list.
Battery Health is evaluated by a smart battery sensor that measures Temp, Amps, Volts. The battery internal resistance and charge level are calculated under load by the sensor.
You can easily force a BATTERY-RELEARN by power cycling the small connector from your Hyundai sensor.
You'd want to do that after working on your charging circuit to better tailor the ALT voltage profile.
W212 can display the live Batt sensor Amps/Volts under "Engineering Menu"... an interesting scene to keep an eye on while driving on highways.
My 2016 E350 did exactly the same when I replaced the main battery (as others have posted), and I expect all cars do the same with a new main battery.
