Should I do maintenance based on mileage or time?
A quick Google search says it includes automatic transmission oil & filter replacement - A7 Service
Maintenance booklet says transmission oil & filter is replaced every 60,000 miles / 6 years.
My car only has 39,000 miles (I don't drive much).
Is there any reason I should stick w/ the 6 year recommendation, or can I wait till 60,000 miles?
On a different, but similar subject - my wife only drives her car < 3,000 miles a year.
Should we change engine oil & filter on that car every year, or only at certain mileage intervals?
I've replaced too many transmissions (other brands, not MB) due to ham-fisted techs who power flush trannies, only to have dislodged particulate matter destroy the mechanics. So, the fewer number of exposures to such antics works for me.
So, I consider 60,000 to be a "precautionary" suggestion... my C320 went WELL BEYOND 60,000 miles without any problems at all.
All fluids have a shelf life. If you run that fluid longer than what's advised, it's breaking down and not performing as well as it needs to. It'd be like drinking a Pepsi from the 80s. There's a chance the food poisoning won't be too bad, but why risk it?
That was such a good analogy.
-the services based on mileage are set by German engineers
-the services based on time are set by US lawyers and that happen about year 2002.
My 1998 ML320 did not have clock in FSS and since that was our weekend warrior it was getting oil changed about every 2 years. Bare in mind it was dino oil in those years.
I also had lot of other toys, like tractor, motorhome, boat, pressure washer, where engines were putting very low annual hours.
I never hesitated to keep the oil in those for 6-8 years.
But I live in dry climates where crankcase water condensation doesn't apply, so that is something you might want to check.
If in doubt- send the sample to Blackstone, or other lab.
Interesting reading without manufacturer bias. Hygroscopic Brake fluid have shelf life, regardless of mileage. It is basically a function of time exposed to air.
Owners manuals use either mileage or time to describe shelf life or estimated wear. They do not know if the car was standing for 10000 hours at fixed RPM, or driven nonstop the whole year; therefore, they are estimates trying to cover most common usage. I think they are using an estimate @10000 miles/year to convert between them
I guess that ignoring service guidelines for the car goes along with ignoring doctors recommendation for better quality of life long term. It is all about the long run. If we are planning to pass the problem to someone else and save a few bucks, sure ignore all the guidelines and reinvent all the engineering put into every product out there.
I use 200 hours for engine oil or 5,000KM or 9 months as maximum, whichever comes first.
Engine oil degradation is first and foremost by temperature above 80C.
https://www.machinerylubrication.com...perature-limit
https://www.shell.us/business-custom...-viscosity.pdf
https://www.shell.us/business-custom...viscosity.html
The rest of the oil killer are contamination from combustion by-products, water vapor from short drive, wear and tear particles from moving parts + etc etc...and low quality oil.
1 of those MB did show signs of negligence, yet it still made 2500 miles home, where I could take care about small stuff.
So per my experience, those cars can take pretty big abuse and still perform. Note that MB engines usually have oil pans with capacity 2-3 times bigger than comparable engines of other brands.
That said, my latest purchase is GLE, who was bought, maintained and traded at the same dealer. After taking the trade - the dealer spend $2400 on sale preparation, so I have new tires, brakes, damaged spoiler got replaced and more.
It come with higher price, but with 120k miles on it, the car has only single ding in hard to see spot. It is pristine.
I had our black W212 sitting for 2 years, started once in the period. After sitting for about 16 months, the diesel engine fired on 1st turn. The only precaution I did was disconnecting the battery and draining DEF.
I also restarted couple of motorhomes who were sitting for 8 and 10 years. Diesel fuel was just fine, so new batteries and here we go.
The one sitting for 8 years drove on original tires just fine as well, but the semi-truck size 22.5" tires have way more rubber on the sides than passenger car tires.
Now guess how many years our 1922 Ford T was sitting?
to each his own, but I have always done better with following the manufacturers advice on maintenance, I just think if I ever do sell it, having all the services done and up to date is perceived value.
I understand that either the hydrometer or pH test should be sufficient. Others use the "eye test"
. Since I am color blind that one does not work for me very well
DON'T JUDGE FLUIDS BY THEIR LOOKS
That is what labs are for.
I am not much of the chemist, but suppose replacing coolant prematurely, without replacing chem pack can put whole chemistry in havoc.
