Sponsored by: CARiD
AFter hard acceleration and letting off gas,upshift is very slow?
Old Nov 21, 2021 | 03:00 AM
24flinchin's Avatar
2013 E550
2013 e550 4matic. This may be because the turbos are still spoiled up but this is my first Mercedes and first bi turbo car so im not sure. After a hard acceleration when I let off the gas it seems to take quite a while to change into the next gear so it sounds as if the revs just hang there for a few seconds before deciding to change into the next gear. Hopefully that makes sense? Is it normal?
Old Nov 21, 2021 | 07:02 AM
RA72825's Avatar
You mean on downshifts as you slow down?
How many miles on your car and has the transmission fluid been changed?
Old Nov 21, 2021 | 08:30 AM
24flinchin's Avatar
2013 E550
Let’s say I get on the gas pedal hard from 2nd into 3rd gear and the RPMs are high and I let off the pedal totally when RPMs are for example 5600rpm, it just holds the rev and doesn’t up or downshift for a couple of seconds. Then it’ll shift and drives normal after.
It has 41000 miles and im not sure about the trans fluid, I just recently bought this car.
Old Nov 21, 2021 | 09:32 AM
RA72825's Avatar
Is this in Sport mode? S
My 2014 E550 does not act like that. I have 62K miles
Old Nov 21, 2021 | 09:38 AM
24flinchin's Avatar
2013 E550
It is indeed in Sport mode. Concerning that yours doesn’t do it, guess I’ll need to investigate more. Thank you
Old Nov 21, 2021 | 09:46 AM
E55Greasemonkey's Avatar
This place is a joke.
Normal. The transmission is ready for aggresive driving and holds the gear longer.
Old Nov 21, 2021 | 10:25 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
It suppose to upshift in this situation.
Those transmissions have adaptive programs and adapt to driving style. That happen faster than some might realize. I was using manual shifter for engine braking coming from steep hills. 5 minutes of such driving and the transmission would hold low gears for following miles of flat drving.
Old Nov 21, 2021 | 12:46 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
Yes - my 2015 E400 also does that. When you jump on it and hold a gear to high RPM's, then abruptly let off the throttle completely, the engine speed just hangs up there. It thinks you are going to get back onto the gas and keep going aggressively. It can't "understand" that you really just want to blend back into traffic. . .
Old Nov 21, 2021 | 01:08 PM
kajtek1's Avatar
When I highly admire "German engineering" when it comes ot MB software programs, too often I have to ask myself. "what those guys smoke for breakfast?".
My GLE is having 200 HP diesel I4 engine. Even it is lovely engine, moving heavy vehicle on 4 cylinders takes some time and I think for that reason the software will redline the engine on 1st gear, even when I just touch gas pedal. Often I am in heavy traffic and I have to step on brake as the result. CRAZY.
It is what it is and learn to deal with it.
Letting the gas off 1000 rpm before redline comes to mind.
Old Nov 21, 2021 | 08:54 PM
MB_FanAddict's Avatar
Arrow
Last edited by MB_FanAddict; Mar 20, 2024 at 06:31 AM. Reason: Forum content removal
Old Nov 22, 2021 | 12:30 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Mine is identical. I just use the paddles to get it back to normal (or just wait).
Old Nov 22, 2021 | 02:12 PM
24flinchin's Avatar
2013 E550
Thanks all, I feel a lot better about it now that I know it affects others as well.
