Do M272 common issue still exist after 2010?
Just wondering if the issues with the balance shaft, timing chain and intake manifold flaps exist after 2010.
I have a E350 2010 build wagon /estate RH drive and so far (touch wood) it's been a gem completed almost 60000kms since I've had it and now has 140000kms in total. Generally commutes local and mainly short trips but at the end of the year we do 1000km+ trips and wouldn't want it to let us down.
VIN/Chassis:
WDD2122562A241898
Engine number:
27298031501017
Thanks in advance
As a preventative maintenance measure I'm thinking of replacing them, what is a recommended brand??
the intake manifold failure is due to failure of the oil separator/ crankcase breather on the left bank, the manifold later gumms up, and plastic lever actuator ( mechanical fuse ) breaks next before the internal flaps makes it even worse.
For preventive maintenance I would do the oil separator, the breather system first.
The next point of failure would be fatigue of the plastic actuator up front the intake manifold. Replacing it? Your call, and your $$$.
My 2c
My 2c
I have changed the oil centrifuge on the RH rear of head and I'm assuming you are taking about the oil separator located on the LH valve cover. I've notice since I replace the centrifuge oil consumption went up, I wonder if it's related to the oil separator I didn't replace.
You can move the external lever by hand. If it's really difficult to move, it's not long for this world. It's kind of tricky to tell unless you know what it *should* feel like, short of it being obviously tough to move.
Getting a tool down to move it will be tricky, but I believe it can be done.
As the manifold issue won't strand us on the side of the road I'm going to wait and see considering I have replaced the PCV valve on the back of the head and I don't really want to spend 1500AUD right now.
https://www.fcpeuro.com/products/mer...kit-oem-515810
There's a rebuilt manifold out there, I think around $350-$400 but I think in some other thread someone railed against them as theirs failed and their warranty was only good if a professional mechanic installed it and it was only one year. FCPeuro has a lifetime warranty and I didn't want to risk having to pay for the job twice, I figure I'm all set for another 100k or more, probably check/replace the oil separator/cover in another 50k or so.
