Blue-green oil leak
Can anyone tell me what fluid is blue-green and oily? No strong smell. Definitely doesn't look like engine oil or gear oil.
What color is 722.9 transmission fluid? Is it red like most ATF?
I found a small puddle of this stuff in the center of the parking spot, toward the front of the car. I'm thinking hydraulic fluid or something from the transmission or front differential. Does the car have steering hydraulics even though the system is described as electric power steering?
I will investigate further when I get the car back- currently it's at the detailers, which is why I took the time to clean the garage floor and found the puddle.
The secondary coolant tank near the firewall (the really tiny one) has pink coolant in it, that I'm sure about. I don't know if the main circuit has different coolant or not.
My old W204 had blue coolant, like my old Volvo and my BMW.
Coolant isn't "oily" in feel, though. It's a bit slicker than water, but maybe I'm overthinking this. Would a radiator leak get caught by the belly pan and end up much further back? Any ideas on what typically fails in the cooling system? This car only has 50k miles on it.
I am not sure what is the difference between "oily" and "slicker"y for you, but while changing the radiator overflow reservoir (W211), I got coolant on my hands and the wrenches/ratchet slipped from my hand while picking them up, is that slippery enough to be called oily?
So if it's coolant, which, after talking to a few people and reading here, it probably is coolant- then where are the typical points of failure? Judging by where the pool was, it was by the firewall, pretty far back from the radiator, and dead center.
Thanks for everyone's help and for putting up with my stupidity!
