Sponsored by: CARiD
Good Mechanic near Scottsdale AZ?
Old Jan 18, 2022 | 01:28 PM
Lapsalot's Avatar
2011 E350
Hi, wondering if there are any private mechanics in Phx/Scottsdale area. My 2011 E350 has intermittent climate issues. The blower blows sometimes, others it's dead. Dealer and another place Scottsdale European told me it might be blower motor or might be relay. Both want almost 1000 dollars to fix, looked up parts they're pretty cheap. Also read it's an easy job. Am I getting ripped off? Hoping a mechanic with less overhead won't overcharge. What should I do? Thanks much!
Old Jan 18, 2022 | 02:45 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
overdue maintenance...
One thing leads to another:
When dirty old filter restricts airflow, the electronic voltage control gets too hot from the high blower current with tight sleeves.... well engineered for easy fixing.
You can buy these parts yourself and be done under 30mn!
  1. Blower fan
  2. "Resistor" (MosFet PWM)
  3. Cabin filter !!!
ASAP....:
Act sooner than later because the Comand display relies on external air flow to cool down. Comand uses internal fans to reject heat in the dash cavity hopefully cooled.
(FYI: Tucson has an highly praised MB dealer in case you ever need top brass)
Old Jan 18, 2022 | 03:04 PM
Lapsalot's Avatar
2011 E350
  1. Blower fan
  3. Cabin filter !!!
ASAP....:
Thanks. Do you think I could find a vid on youtube on how to swap filter, and possibly blower/relay?
Old Jan 18, 2022 | 03:14 PM
easy does it!
Yes, for sure! It's as easy as it gets. Any housewife can tackle this repair.
NOTE :
When you drop the under pannel, go easy and be sure to gently remove the temperature sensor located towards the center console. The second wire is connected to light bulb socket.
Old Jan 18, 2022 | 03:19 PM
Lapsalot's Avatar
2011 E350
NOTE :
Canceled my repair appointment, you just saved me a bundle. Much appreciated!
Old Jan 19, 2022 | 04:07 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
NOTE :
Here are some videos
Old Jan 25, 2022 | 06:38 PM
Lapsalot's Avatar
2011 E350
  1. Blower fan
  3. Cabin filter !!!
ASAP....:
Can you be more specific on resister? Where does it go? What exactly do I buy? MosFet PWM?
Old Jan 25, 2022 | 06:45 PM
repair parts... kit:
Solution:
look for a parts kit at your favorite part store or parts counter. I don't have an EPC reference.
"Resistor" MosFet PWM:
The electronic module that controls power to adjust blower speed. In the old days it was a set of resistor before it got upgraded to power MOSFET transistor to chop DC voltage into a PWM.
Old Jan 25, 2022 | 09:15 PM
Lapsalot's Avatar
2011 E350
Solution:
Still unclear, sorry.
Old Jan 25, 2022 | 09:47 PM
blower kit
official sponsor... love to see u 😎
pricey voltage control... pass unless failed
After searching for these parts.... I see some blower motors types have a built-in voltage controller. As always you need the PN applicable to your specific car.
Old Jan 25, 2022 | 11:53 PM
Lapsalot's Avatar
2011 E350
Got it. I actually figured it out before I saw your post, but wasn't sure. Now I am. Thanks much! Some great people on this forum.
