Advice on carbon cleaning M276 motor
walnut blasting is something you might do if you've already got the engine apart and its really crusty inside. it is definitely not something you want to take the engine apart just to do on a maintenance basis.
I have 176,000km on my M276 Engine and have not done any carbon cleaning. I do lately have a slightly minutue longer crank by probably 0.2sec.
I also don't really recommend engine flushes, heard horror stories from friends and others around the deposits seizing the engine when broken off.
So all DI engines do have this occurrence, again, some need it a lot more frequently than others.
Chris
EDIT..Techron or any fuel types or additives will not clean or solve this issue with DI engines. It would have to come through the intake if it were to work at all.
Supposedly MB engines are not so prone to excessive carbon build up like older or early 2000s Audi and VW Tsi engine.
Some BMW also known to have more carbon build up than the Benz.
Here is a good example of newer 2019 Golf engine ( supposedly cleaner ) and the inherent carbon build up a DI engine will have, be it little or plenty....at 10,000 miles.
More mileage, more build up
Surely engine oil and fuel quality will matter in carbon build up reduction, but having oil vapor on purpose injected into our NOT A PORT FUEL INJECTED engine as part of "green" , will introduce carbon build up at your intake valve,
like it or not.
Last Dec 2021, I was tempted to remove my intake manifold ( at 34,000 KM ) to be able to see and clean carbon build up at my intake valves, but I changed my mind because
I have to remove lots of wiring assy connecting to sensors which so happened to sit above the intake manifold. Also there is a wiring plastic box hiding the wire assy with fragile clips which is a pain to undo, need special tool to be safe.
I already have all the gaskets. Sending my probe camera was impossible, some kind ofpartitions inside the intake manifold was blocking.
Below are photos during a fun project inspecting/improving/cleaning engine bay grounds. This is for 276 3.0 Turbo owners if they want to do valve cleaning, components you need to remove.
1st remove the ECM & bank 1 + 2 air filter box - EASY
Removing the cover of the wiring assy plastic box is a pain in the azz, if you do not want to break any of the 15 or so plastic clips.
A special fish hook shape tool must be made if the un-clipping to be done without risk of breaking those clips. None of those plastic interior prying tool kit work for this clip.
Below is the FEMALE clip to be pried 20 degrees or so.
The above female clip, latches itself at the MALE notch below.
Apology for my poor drawing, but below is what the special tool would need to look like.
Special Tool must be metal, thin and stiff. The interior plastic prying tool is too flexible and too thick. The FEMALE clip is very stiff.
When the plastic box cover opens up, these are the wire assy needed to be removed side way and most may need related sensors/devices connectors to be first unclipped. Damn, a real hassle.
I cant , at that point in time, totally unclip the most rear part of this plastic cover, those near the fire wall. I think 3 more FEMALE clips to go. I can't see them well and no room to work with ease.
M276 3.5L NA seems so much easier to do upper intake manifold removal.
The best image of carbon build up I can get was thru the spark plug hole, but its too difficult to assess based on those, but it is evident my valves have some carbon build up.
https://mbworld.org/forums/e-class-w...ke-valves.html
The part I hate the most on my engine is the position of the aftercooler is in front of the main pulley and so tight, I can't fit the size 27mm socket to spin the crankshaft to see more
valve opening. So aftercooler must be removed to spin crankshaft. DUH.
The last time , 2 months ago in Dec 2021 when I did remove my aftercooler to clean oil leak traces from timing cover and replacing all 4 camshaft magnets which my version supposedly will leak and introduce oil into
ECM wire assy, I forgot to inspect the intake valve via probe camera thru the spark plug hole ....errrggg.
However, I plan at 50,000 KM to inspect and clean the intake valves for preventive maintenance & learning sake.
That means 3 years from now
*For the record, I just turned 61. According to my investment advisor, the actuarial tables estimate I'll live to 81. So we're talking about 20 years here.
What ever additive you put is simply YOU WISH IT WORKS
