Air inlet ducts
Mine ripped and I don't want to replace with original, kind of flimsy
I'm assuming you are talking about the highlighted ones right? I've only seen the super expensive carbon fiber replacement ones.
I actual got them from my local Autozone for $20 a piece. They come with 2 rubber couples each as well. The brand is Spectre and model number is 8741. Every Autozone I went to stocked it. Usually only one so might have to visit more than one.
The two I have on are as small as they go so you may be able to get away with just one and cut it. you would just have only 2 couplers which would still work bc they are really only needed on the oval scoops at the front! LMK if you have any other questions!
left
right
complete with spectre parts
left
right
one thing that is stopping me is HOW DO YOU GET THE ROUND SHAPE END OF THE PLASTIC BEND TO GO IN AN OVAL SHAPE BLACK PIECE in front?
can i just bend it to shape , or does it come with some type of adapter?
for 20bucks each these are way cheaper than $70+ for OEM replacement
1. the adapter will bend on to the oval shape
2. HOWEVER, do you see that white wire? you have to pull it off completely from the oval connector of the car. The reason being is that will pull all of the fabric off the factory connector and the spectre piece will slide right on. If the fabric is still there it will not fit. Once you get it over the oval piece you have to test fit the rest and may have to cut a little off of the driver side. Keep in mind the passenger side needs more material so measure first (I learned the hard way) before cutting. This took me all of 10 minutes to do. Really simple.
so you think 1 kit will do the job if measured correctly? or 2 kits are necessary because of adapters that come 1 per kit?
And yes i went with red in hope of extra HP lol
I appreciate everyones help. Great fix without spending crazy money on oem piece. Love this forum.
i did think of some clamps or smth to make sure it doesnt come off , but after checking them agai this morning i think they will be fine as is.
off topic. when we ordered the mustang i was contemplating on the color. mrs blurted out, "red! so its faster!" we were both smiling and the sales rep was looking at us clueslessly.
and yes , its that level of understanding where sales reps or other ppl dont get it.
hoping someone can help me, i have been trying to locate part # 273-090-26-82 Air inlet ducts for my car. Every dealer and aftermarket place i have searched have been no help so far. Seems parts have been discontinued. Is there anyone out there that knows of any aftermarket parts source that will work or any source for look to find replacement parts. hope someone out there can help
