Sponsored by: CARiD
Diverter Valve for Turbo - M276 3.0TT and M278
Old Apr 7, 2022 | 11:01 AM
S-Prihadi's Avatar
Diverter Valve for Turbo - M276 3.0TT (corrected)
CORRECTION : M278 does not have this diverter valve. My bad. Title been corrected
I was inspecting mine, Bank 2 only due to easier access, so I am sharing.
This diverter valve is known to leak overtime from tearing of the silicone membrane. You then loose boost. Made by Pierburg
Installation depth is 18mm.
The 18mm shown by the caliper is where the "piston's top seal" will park itself when installed.
18mm is also the position if you want to test the magnetic coil pulling down on the piston, more than 18mm the metal section of the piston is too far up and magnetic field can't pull it down.
Position. B1 is Bank 1, so B2 is BANK 2 ( Left Hand drive car driver side )
Audi/VW engine due to high population count and they are mostly turbocharged, uses this type of diverter valve too and is easy to get info on them on Youtube.
VW/Audi has done so many revisions on this component. I believe the piston diameter is smaller 22mm there about.
Too bad our MB seems to use the older design which VW found not so robust
Its a simple ON-OFF switching by ECM. 2 wire connector. No fancy frequency or PWM duty cyle yada yada. This diverter valve uses 1.2 amps at 12V.
My test
Old Nov 20, 2023 | 11:15 AM
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
good topic, any idea how i can notice if my "diverter" valve is not good?
I do half boost or maybe for an moment a bit more but not more than 3/4 on the AMG gauge screen, I changed transducer valve + pcv valve (with the orange diapraghm on the vacuum pump) car is better in terms of performance but still same boost is doing and idk what might be..
I tried myself to unscrew the diverter valve on Bank 2 to check if something is wrong with it as you stated above but i didn't manage to do it, it's really hard to unscrew it for some reason.. i can't imagine how difficult will be to be unscrewed and to reach to it on Bank 1..
Old Nov 21, 2023 | 12:57 AM
S-Prihadi's Avatar
Kis asked : any idea how i can notice if my "diverter" valve is not good?
That is a tough question if you do not remove the diverter valve for proper inspection.
While a diverter valve is not a boost control mechanism like that wastegate vacuum actuator controlling the coin shape wastegate at the turbo, it does control boost too but not for peak boost, but rather not to waste
boost and prevention of unwanted shock-wave at the turbo. Go to page 15 to 17 of the M276.8 engine information document. Attached full PDF
Now, this diverter valve is a NORMALLY CLOSED valve, different to the wastegate coin shaped metal "door" at the turbo which is loose if not supported...and we can call it as NORMALLY OPEN valve.
The nature of the operation of the wastegate vacuum actuator is also a NORMALLY OPEN, this is for safety reason for sure... safer to be under boost than to explode the engine if over boosted when and if
the design of the wastegate system is a NORMALLY CLOSED one.....and it failed.
The diverter valve has a spring to fight or keep shut the polymer seal as per the design pressure of the turbo plus some extra. How many PSI/BAR, I do not know.
One thing for sure, my engine M276.820 is only a 0.8 BAR max boost, a C43 with higher horsepower M276.823 could be like 0.9 to 1.0 BAR.
By logic , if one is to design a mechanical spring based Normally CLOSED diverter valve with electrical assist to open the valve sooner than what the spring would do on its own,
it would be a few percent higher only than the maximum pressure of the turbocharger...again as safety measure.
So if say my engine is 0.8 BAR max boost, I think the engineer would choose the divert valve to have a counter spring to be no more than 1.1 BAR which is already a lot.
0.3 BAR increase from a 0.8 BAR is 37.5% increase and that is already decently plenty.
In an event one tune the car say to 1.5 BAR max turbo boost, that diverter valve spring overtime would probably be weakened if not the seal get damaged.
It probably wont be an instant damage/defects at such modified increase boost, but overtime the diverter valve which is not design for 1.5BAR, would surrender and goes leaky
Old Nov 21, 2023 | 06:07 AM
Thanks again for sharing feedback on this topic
I've really strange behaviour when car is on Comfort and on higher gear if i press bit more the throttle is trying to build boost almost to MAX as you can see in the video below, but if is on lower gear and higher RPMs (2100 for ex) is not doing full boost (when throttle is pushed to the floor) so I am really confused why this might happening
Also does both turbos are working constantly or one is for lower RPMs and other one is for higher RPMs?
Either not sure if car during building boost can loose boost through the diverter valve, i will try soon to dismount both of them and check if the rubber seal is fine
Old Nov 21, 2023 | 12:42 PM
S-Prihadi's Avatar
I've really strange behaviour when car is on Comfort and on higher gear if i press bit more the throttle is trying to build boost almost to MAX as you can see in the video below, but if is on lower gear and higher RPMs (2100 for ex) is not doing full boost (when throttle is pushed to the floor) so I am really confused why this might happening. << This is normal, you are lugging your engine if you expect turbo to boost a lot at lower RPM.
Also does both turbos are working constantly or one is for lower RPMs and other one is for higher RPMs? <<< NOPE. our turbo is not sequential turbo, it is small turbo x 2, each bank get 1 turbo. Our engine is V6,
so it is practical to use 2 small turbos, one for each bank. If inline 6 engine having 2 turbos, it can be sequential turbocharging .
Video
Our engine is torque limited by the computer.
Your must understand what is torque in respect to horsepower.
Read here : https://www.caranddriver.com/news/a1...he-difference/
This is your engine calculated torque and HP chart. I say calculated because I do not have MB official document on it.
This is my engine official torque and HP chart. My engine is M276.820 and yours is M276.823
So your ECM would want to keep your engine at maximum 520NM of torque, as to not damage it.
When at low RPM, this is your calculated engine HP output
So when at low RPM, the room for torque limit is still available, your engine would boost more to achieve that.
If at higher RPM the high torque is easily available already and limit can be reached easy, so no need much turbo boost anymore.
See my engine log below. It is 5 data points per second.
The high boost are at the lower RPM mainly, because that is how MB set the engine to be.
As long as in cold enough weather say 25C and engine is not heat soaked , if you can hit 95% of your engine target boost level ( MB setting ) during a 1st, 2nd and 3rd gear WOT to redline,
there is no obvious leak anywhere on your system.
Do not ever think the boost can stay high all the time, no.... that is not how our engine behave.
Data point region 2500ish
Data region 7,700 ish
This one using Xentry and I can see the torque in Newton Meters.
Go and test your engine WOT-Redline in 1 to 3rd gear. Log it with a logger at least 2Hz data points and see what is the result.
Drive safe...
Old Nov 21, 2023 | 03:06 PM
The difference before the ECU/TCU updates is that now car not produce the full boost with the remap which i am with right now (and before the updates was the same remap) i don't get why before was hit full boost all the time no matter if car was on higher RPMs or lowers no matter of the gear (2nd or 5th).
Since my car don't have CPC there shouldn't be some new added limit on the ECU/TCU somewhere for the Nm/Tq isn't it?
That makes me to think what could be wrong currently, please check both videos below
P.S. I did another video with brake boost if this can bring some clarity, unfortunately i dont have obd scanner so i can't pull the data for now which you asked above
Last edited by KristiyanPetrov; Nov 21, 2023 at 07:30 PM. Reason: wrong attached video
Old Nov 22, 2023 | 02:07 AM
S-Prihadi's Avatar
Does not mean you car is not getting that anti-naughty CPC module like newer cars...............MB can't protect their engine computer and tranny computer with a newer software.
Even engine Start-Stop kill feature took years for 3rd party scanner to be able to KILL the feature, which was actually a simple non protected variant coding.
Get your tuner to do his homework based on the latest update software you got from MB on your 2 computers.
I am sure you have a proper decent scanner or some sort of BLACK-BOX which can read such information ?
Also do not trust a 100% what the display is showing you. Use OBD2 based data reader and read direct from the engine computer.
If there is another device in M276 3.0 Turbo which can leak a boost, it is the duo check valve at the intake manifold, which is for injecting fuel vapor from tank and oil vapor from engine crankcase.
Read here : post 79
https://mbworld.org/forums/e-class-w...ml#post8849390
Old Nov 22, 2023 | 05:30 PM
Read here : post 79
Unfortunately i can't go to him because he is based in another country and is really painful for me to travel for 3rd time to him (i went 2 times back to him only because the car was more than great and this software on the car was for 2 yrs) and now after the update he don't know what is happening and the final result is not the same as before
I just remember i have this photo with what was updated and i tried to find info on the software versions which are updated to look as ref what contains the update but i can't, do you think i can find somewhere such info on this?
Today i was about to check with mechanic live data but was rainy and i didn't go but in the next days when im free i will jump to him, but he have some obd scanner not Star diagnostic, so not sure what exactly to look on this OBD scanner and to send to you?
Here is the image Xentry from dealer prev/current versions what was updated
Old Nov 22, 2023 | 11:22 PM
S-Prihadi's Avatar
So....W205 gets N127 - Control unit POWERTRAIN - PTCU
This is probably an early generation of the CPC.
Find attached the information on N127.
Basically N127 is a gateway and that is NOT GOOD for anyone trying to mess with software.
Sorry I can't help you further. software is not my thing.
ADD : My W212 does not have N127. As far as I know, no gasoline W212 gets N127. Its a new thing for W205 and W213 before newer CPC module during facelift ?, I guess.
File Type: pdf
Old Nov 23, 2023 | 08:49 AM
Thank you, yes it might be idk either, that's why i was curious what contains this SF update, i found recall for Powertrain and ECU on W205 which the codes matches with my Xentry, but not sure why and how is affecting the boost, i found another guy who have the same situation as me, he had the TCU update and since then don't have full boost and can't find the reason (this is on stock map)
The ECU N3/10 update is about some emissions to heat catalyst on every start up on the car (which I notice that everytime when i start the car even if i drove for 2h and turn it off for 5-10min will idle to 1400RPMS really annoing) - https://mb.oemdtc.com/1096/update-en...lass#more-1096
The TCU N127 update is about - the powertrain control unit may not correspond to the current production specifications. It is possible that the next maintenance interval is displayed to the user as a negative distance reading in the instrument cluster.
https://mb.oemdtc.com/1652/update-po...lass#more-1652
Old Nov 23, 2023 | 09:33 AM
S-Prihadi's Avatar
Well, MB may have written other things in the software while at it
They won't tell you the color of their "underwear".... LOL
Emission and Power are mortal enemies. This we have to remember.
Old Nov 23, 2023 | 09:44 AM
Yes for sure, i really get so annoyed when i went to the Dealer to get my car from Service B (and before i left it i told them don't touch anything else apart of the servicing oil, filters, spark plugs) and when I look the face on the Service Manager it was proper guilty one that he did something that it shouldn't and when I jump on the car and went off the CEL appear and i told myself | "i knew it.." and on the next day i went back and they told me yes you don't have catalyst is normal to have CEL and i asked why did you touch Software without my permission? and he was oh sorry we can't do anything this is what we should do bla bla.. so for 6 months i can't figure out what is happening.. and i really get a bit sad because my car was more than enough powerful and enjoyable :/
Apart of that, after you saw my videos do you think there's any chance some of the Diverter valves can be not fine, i will check them anyway when i've time but just to see your opinion on this
Old Nov 23, 2023 | 09:51 AM
S-Prihadi's Avatar
I can't comment on your diverter valve possible issue, merely from that video, unless the diverter valve is fully torn and you wont get boost at all.
If its spring gets weaker due to non standard boost, well it can reduce your tuned boost request.
However, if the drive-ability of the car is good as stock car, I believe all this is from software "lock".
If new software is so concerned about emission, missing the CAT and getting CEL is a big deal for the engine computer and probably N127 too.
Emission matters is what car manufacturer fear the most.... more so in USA and California.
Old Nov 23, 2023 | 09:58 AM
Will see, if i've any updates on this will post it here in case someone else have same problem (hope no one)..
Old May 1, 2026 | 10:58 AM
Morflavo's Avatar
2017 C43 AMG
Kristiyan, did you ever solve this problem? I'm having the same issue a few years later with my own C43. What was your problem?
Old May 3, 2026 | 06:22 AM
The issue with the boost was according to one tuner was that my Throttle body wasn't set to open as much it should and from there prevents the boost
Not sure what is your case exactly tho
Old May 3, 2026 | 07:49 AM
W205C43PFL's Avatar
Was that caused by the tune or just defective throttle body?
Old May 3, 2026 | 08:09 AM
Something with the tune, strange thing is that with prev tune before the updates i didn't have that issue, so idk why that was happened
Old May 3, 2026 | 08:16 AM
W205C43PFL's Avatar
Hmmm incompatibility or maybe the update changed the throttle body behaviour and the tune was incompatible?
Old May 3, 2026 | 12:50 PM
it might be, not really sure what exactly the update contained and how affects my tune file
Old May 3, 2026 | 04:24 PM
W205C43PFL's Avatar
Ya perhaps, either way, at least that problem is dealt with.
Old May 12, 2026 | 09:03 AM
Morflavo's Avatar
2017 C43 AMG
Do you know how much it was opening with the limited boost? When I set my creader to track throttle position it only opens to 85%. That could be torque limiting or maybe I have the same issue. Although I don't have a tune so I'm not sure why that would be the case. My throttle pedal also reads 85% before the kickdown, and when I hit the kickdown switch it jumps to 90, but throttle blade stays at 85%.
Old May 12, 2026 | 09:53 AM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
You and I are chasing the same problem. I've already done my check valve, which seemed to help slightly. My E400 is running stock numbers (5.5 seconds to 60) with a eurocharged tune that's supposed to add 150HP. When I flash the ECU back to stock, my E400 is running 0-60 in the high 6 seconds range. So frustrating that there's no codes or anything obviously wrong.
At higher speeds, once already rolling, the car does seem to perform much better. But just punching it off the line without brake boosting it feels like there's a full second before anything actually starts happening. My mother owns a W212 e350 that feels quicker off the line at first, but it of course starts in first gear regardless of whether or not it's in sport or comfort.
Old May 12, 2026 | 10:02 AM
Morflavo's Avatar
2017 C43 AMG
Very interesting. That does sound like my problem. I have a new GFB Diverter valve that is arriving today, I htink my passenger side is on its way out. My boost gauge builds to about half when I just punch it in low gears. I have a whole thread about it here. I've tried seemingly everything including resetting my ECU/TCU learn parameters, checking for and clearing any codes that could trigger limp with my launch scanner (there were none), removing the torque limit, new check valve, checked play in my wastegates, smoke tested for boost leaks, new wastegate control solenoid, checked for vacuum leaks to the wastegates, checked for vacuum leaks IN the wastegates, checked seals on my driver side (LHD) diverter valve because it's the only one I can easily get to, and I've come up with exactly nothing. So I'm going to upgrade the passenger diverter valve to a GFB T9488 as a hopefully one-step fix for now, and do the driver side later. The only other thing it could be is me not being able to feel the play in the wastegate bushings, and I have an exhaust to install, so I'll pull the downpipes and check the wastegates while I'm under the car.
Old May 12, 2026 | 06:26 PM
i really have no idea how much was opening but just guessing that the culprit on your case shouldnt be the throttle body, and you said you're stock so you eliminate a lot of guesses, but i saw in your last comment that you have checked all possible scenarios.. have you checked what the car produce in bars commanded vs actual boost or maybe visit a good tuner to inspect live data while you drive and see if he find something wrong
P.S. back in the time when i had the problem i started with diverter valves, transducer valve that controls the wastegates (that didnt solve my problem due the tune that didnt open the throttle enough) and the garage that changed the diverter valves seems didnt tightened my bank 1 diverter valve enough and over time from vibration i guess was get loose and after time when my tune was fixed i still have some issues with the boost but was better and during some maintenance on the car underneath we saw that oil was leaking from Bank 1 turbo and we saw that the diverter valve was loose, so make sure when you change it to be tight enough (its kind of pain in the *** to change it anyway..) and hope to find the issue as soon as possible, idk why this engines give so much headache especially if you try to maintain and change stuff preventive (as me)..
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
